Full Remus System
johno
Full Remus System
Post by johno »
I have a full Remus system to put on my R, and was wondering if anyone else has one.
I want to know if you put the O2 sensor back in, or leave it out.
I have heard that by leaving it out, it eliminates the surging problem, and doesnt affect gas mileage that much.
Any thoughts???
2002 R1150R.
Re: Full Remus System
Post by riceburner »
johno wrote:I have a full Remus system to put on my R, and was wondering if anyone else has one.
Any thoughts???
assuming you mean the Y-piece and can?
Yup - stick it back. The Motronic engine management system is a "closed-loop" system. That means that it's looking at the exhaust gases while deciding what mixture to put into the cylinders for the next stroke. Without it the system will use a "default" setting (I'd imagine it's been programmed that way), that will work, but it won't be analysing the exhaust gasses..
Post by DJ Downunder »
I don't have a Remus system..but re that sensor..I would put it in.
DJ
mcmarcia
Post by mcmarcia »
I have the remus exhust on the bike I just bought. Bike runs great and I assume the sensor is installed , but I will check it out tommorrow and let you know.
04 BMW R1150RA
92 Yamaha Virago 1100
95 Yamaha Virago 750
Lobo1625
Donating Member #: 611
Post by Lobo1625 »
Johno,
I have a full Remus system on my '02 R and it does have the O2 sensor installed. I have never had a surging problem with my bike. I purchased it with 3600 on the clock and the Remus was already installed. I was actually thinking about posting a 'surging symptoms' thread to see when the surging happens and how noticeable it is, for my own benefit. Other than the Remus I now have a K&N filter. No change in rideablity before or after the air filter, but the bike seems a bit louder. I have heard however that with a full exhaust that the bike should be chipped. I don't know if mine is chipped to compensate for a free flowing exhaust or not, but I have assumed it is. As far as the mileage, on my last trip I topped over 50mpg for 300 miles on some nice highway and great twisties. (I'm sure it would have been better had my speed been closer to the posted limits :D) Around the city the mileage is ~35. Hope this helps.
johno
Post by johno »
I fitted the system last night, and I put the sensor in.
I havent ridden the bike yet, so cant comment on the performance yet.
Hopefully tomorrow the weather is better, and I can go for a squirt.
Definately loud with the baffle out, and not much quieter with it in 8)
2002 R1150R.
m49512
Post by m49512 »
y-pipe, remus exhaust, Techlusion 1031, disconnected O2 sensor. Bike works GREAT w/no surging. :D
johno
Post by johno »
Thanks m49512, for that info. I will see how mine goes this weekend, and may need to chip it as well.
Mine has the Y section as well.
2002 R1150R.
As a clarification to riceburner's post, regarding the "close loop" operation.
You are correct there is a "close loop" operation mode in the Motronic systems where the O2 sensor is uses. However, this "closed loop" only takes place at a precribed range of throttle opening and engine load such as when one is running at steady highway speeds. At this point the O2 sensor is controlling the A/F ratio to the engine, making the mixture as lean as possible to maximize mileage, and of course get you very close to the dreaded "surging" that a lot of owners complain about.
The other mode of operation of the Motronic is referred as, you guessed it, "open loop" here the O2 sensor is bypassed entirely and A/F ratio is controlled entirely by the TPS and the sengine.rpm's. This mode is when you are on the throttle. and considered a power mode, threfore the fuel map is richer than what you would get under "closed loop".
So in answer to the original question:
A) Removal of the O2 sensor does not adversely affect the bike's operation
B) Removal of the O2 sensor, does provide a richer mixture while under steady state operation, potentially eliminating the dreaded surging.
C) If you do a lot of steady state cruising you will probably notice a decrease in mileage
D) If you do a lot of stop and go and change throttle openings often, you will probably not notice a mileage penalty.
E) You don't have to physically remove it, but break the connection just behind the tank on the right side of the engine.
In closing, take your pick from the above and enjoy the ride...... 8)
johno
Post by johno »
Thanks Boxermania.
I have heard that disconnecting it and leaving it in can damage the sensor, so if wanting to reconnect it later maybe useless.
I will run with it connected for a while and see how it goes. Then disconnect and try, then decide which way to go.
2002 R1150R.
johno
Post by johno »
Went for a 100+ mile ride yesterday, and am impressed.
Seems to have more mid range punch, not so noticable up higher, as I allready had a pipe on before(home made) that helped up high.
I like the noise, very pleasant.
2002 R1150R.
REMUS
I have the Remus with the Y pipe. I removed the baffle in the can. The intructions said this would make it no longer street legal. I did not notice any difference in decibel level. Anyone else have any notes on this?
johno
Post by johno »
I must admit, I didnt notice much difference with the baffle out, to in.
I have put mine in anyway, so at least it looks legal :D
2002 R1150R.
jcIII
remus exhaust
Post by jcIII »
I recently installed a Remus Revolution exhaust (can only) on my 04 r1150r, works great surging at 3,000 rpm constant speed disappeared. The engine feels stronger up to redline and the front wheel lifts easier under hard acceleration.
I was told the baffle was removable, the instructions that came with the can did't explain how to remove the baffle. It looks like the rivit on the end of the silencer would have to be removed?? The parts bag came with a extra rivit, I'm assuming this is if you wanted to replace the baffle. Shining a light into the can, I can't tell if the baffle is permenatly attached. Any sugggestions would be appreciated.
johno
Post by johno »
jc111, my baffle is bolted in, but if you take the rivet out, wriggle the baffle, and it should come out.
Unless you need to make extra noise, I would leave it in.
2002 R1150R.
pneuby
Post by pneuby »
I just replaced a Two-Bros (in bad need of re-packing) with the Remus.
NICE! Quieter, as I left the baffle IN, which I didn't expect. My neighbors will appreciate that, LOL.
I SWEAR there's less vibration. Formerly, the vibe I felt intruding as you break 4K RPM is now unnoticed right until the 5K RPM mark. Since 4-5K seems to be the sweet spot for power on my bike, that's a bonus. :wink:
Parkblu
Location: SE Florida, sometimes Munich, sometimes Raleigh NC
Post by Parkblu »
I had a Lazer and now have a Remus with removable baffle and y-pipe; quite happy with the sound, and certainly not loud, even without baffle. I'd be lying if I can tell major changes in engine characteristics though.
Osiris
Post by Osiris »
Hey there, folks!
I am seriously considering a Remus exhaust with their Y-pipe and Genesis can. Is this a good combination for the RR? Must the bike be chipped after install? I know that the Revolution is a popular can, but I would like something just a tad bit noisier! :D
Many thanks!!
That which does not kill you...comes back with BIGGER GUNS!!
'02 R1150R Atlanta Blue
johno
Post by johno »
Take the baffle out of the Revolution, and if you want more noise than that, there is something wrong.
I run mine with the baffle in, and I think sometimes it is too noisy under hard acceleration.
I have fitted a chip to mine, and I like it. 8)
With both mods done, it fattens up the mid range real good. :D
2002 R1150R.
AirForceDirt
Post by AirForceDirt »
Okay, so...old thread, and probably this has been answered but I looked..
Has anyone been successful in putting the baffle back IN to a Remus revolution can?
