Sometimes abs pump stays on a bit too long
milehighboater
I have found on fairly hot days by abs pump will stay on till I push the front brake handle forward a bit. 98% of the time it's on and off perfectly. Anyone had this problem before? 2004 r1150r 42k.
Re: Sometimes abs pump stays on a bit too long
check your fluid level, and flush and bleed that system with fresh fluid.. Not sure if that could be a sign something major is wrong... incorrect pressure? or just a mis adjusted brake lever?
Annual ABS service is critical. The iABS system (pump) is not very tolerant of missed services. Also very expensive to repair/replace the pump when or if it fails.
Brake system bleeding is not difficult but maybe a tad tedious. But regular service is a must. I guess I'm kinda saying ya need to do it on a really regular basis!
Mine was neglected for 3-4 years due to illness on my part. As a result my pump failed last summer and I ended up completely pulling the ABS system off my bike. ('04 model) New pump is $2400+, so it will dip pretty deep into your pocket if you have to replace it.
