Can you swear like a sailor.....it's a beach to get to and MO you will not find it at the auto parts store.
All kidding aside, you have to remove the cover. from the rear, there is one screw on each of the covers. The bulb is then accessible, it is a one off and quite expensive, or so I remember. I guess you will have to go and pay your dues at the BMW tax collection agency.
I pulled the round cap off the back of the assembly last night and went no further, does the assembly just then pull out from the front or do I need to remove all the caps and screws to remove the back chrome housing from the entire instrument cluster?
Not that it makes a difference, it is actually err the speedo bulb.
And yes I swear, more like a drunken sailor though.
denverchuck...did you finish the job? i just bought a 2002 and have to replace the speedo bulb? any comments other than those above??
thanks...Don Purvis
gagator,
Remove the two headlight bolts and let it rest on the beak, remove the three ‘disk’ covers and four screws from the back of the instrument cluster, remove the speedo cable and wala, the cover comes off. One bulb was clearly blown, replaced it, still no light, replaced the other and we’ve got light. So get both bulbs and replace ‘em. Tried removing cover w/o taking off headlight, no go. No special tools or instructions just pull the bulb straight out the back of the cluster.
