Crush washer part #
Crush washer part #
Looking for part #ers for crush washers (oil drain plug,Gearbox and FD) aswell, a good place to get them online....
Re: Crush washer part #
If you purchase the BMW OEM oil filter like you should, they all come in the box for free.
Problem solved.
Problem solved.
Not in western Canada.....have done 4 oil changes, not once did I get a crush washer with a filter,seperate item.No leaks yet though.Arbee wrote:If you purchase the BMW OEM oil filter like you should, they all come in the box for free.
Problem solved.
I just changed my gearbox oil...used the old crush washers...no leaks,however its not something I want to practice...plus it would be nice to have spare washers..
Can i suggest that there stealing them, not hard for a stealership, try another BMW joint.possum wrote:Not in western Canada.....have done 4 oil changes, not once did I get a crush washer with a filter,seperate item.No leaks yet though.Arbee wrote:If you purchase the BMW OEM oil filter like you should, they all come in the box for free.
Problem solved.
Green Hornet
You can order from these guys. they have many other parts as well.
http://www.beemerboneyard.com/7119963252.html
Micky
Micky
Micky
2000 Moto Guzzi Jackal
2004 Rockster - Green
If you order the oil filter kit, part number is 11001341616
In 11001341616 oil filter kit, you will get:
1 oil filter (part#11421460845)
1 bag of 5 washers for
- engine oil drain bolt
- transmission filler bolt
- transmission drain bolt
- final drive filler bolt
- final drive drain bolt
If you go à la carte:
Oil filter part number is 11421460845
Engine oil drain bolt washer part number is 7119963252
transmission filler bolt washer part number is 7119963300
transmission drain bolt, final drive filler bolt and final drive drain bolt share the same part number 7119963200
Good One Phang.
Arbee, a quick check in maxbmwmotorcycles.com reveals:
11421460845 Oil filter $19.47
11001341616 REPAIR KIT FOR OIL CHANGE $19.14
It doesn’t make sense, you pay more for less
chicago BMW prices are more realistic
11421460845 OIL FILTER S $18.90
11001341616 REPAIR KIT S $19.14
for a quarter more you get 5 washers
Thanks for all your help....you guys rock
- Dr. Strangelove
- Double Lifer
Do they have to be OEM stuff?
A crush washer is a crush washer is a crush washer, isn't it?
I have only used the OEM ones but it would seem that AutoZone or Advance Auto etc would have something the right size that would work, no?
I just haven't looked yet. Anybody?
'09 Schwarze Blanche DuBois
