Crush washer part #
possum
Donating Member #: 751
Crush washer part #
Post by possum »
Looking for part #ers for crush washers (oil drain plug,Gearbox and FD) aswell, a good place to get them online....
Arbee
Re: Crush washer part #
Post by Arbee »
If you purchase the BMW OEM oil filter like you should, they all come in the box for free.
Problem solved.
possum
Post by possum »
Arbee wrote:If you purchase the BMW OEM oil filter like you should, they all come in the box for free.
Problem solved.
Not in western Canada.....have done 4 oil changes, not once did I get a crush washer with a filter,seperate item.No leaks yet though.
I just changed my gearbox oil...used the old crush washers...no leaks,however its not something I want to practice...plus it would be nice to have spare washers..
Arbee
Post by Arbee »
Problem solved.
Can i suggest that there stealing them, not hard for a stealership, try another BMW joint.
Green Hornet
Post by Green Hornet »
You can order from these guys. they have many other parts as well.
http://www.beemerboneyard.com/7119963252.html
Micky
Micky
2000 Moto Guzzi Jackal
2004 Rockster - Green
Phang
Donating Member #: 707
Post by Phang »
If you order the oil filter kit, part number is 11001341616
In 11001341616 oil filter kit, you will get:
1 oil filter (part#11421460845)
1 bag of 5 washers for
- engine oil drain bolt
- transmission filler bolt
- transmission drain bolt
- final drive filler bolt
- final drive drain bolt
If you go à la carte:
Oil filter part number is 11421460845
Engine oil drain bolt washer part number is 7119963252
transmission filler bolt washer part number is 7119963300
transmission drain bolt, final drive filler bolt and final drive drain bolt share the same part number 7119963200
Arbee
Post by Arbee »
Good One Phang. :mrgreen:
Phang
Post by Phang »
Arbee, a quick check in maxbmwmotorcycles.com reveals:
11421460845 Oil filter $19.47
11001341616 REPAIR KIT FOR OIL CHANGE $19.14
It doesn’t make sense, you pay more for less Image
chicago BMW prices are more realistic
11421460845 OIL FILTER S $18.90
11001341616 REPAIR KIT S $19.14
for a quarter more you get 5 washers 8)
possum
Post by possum »
Thanks for all your help....you guys rock :D
Dr. Strangelove
Post by Dr. Strangelove »
Do they have to be OEM stuff?
A crush washer is a crush washer is a crush washer, isn't it?
I have only used the OEM ones but it would seem that AutoZone or Advance Auto etc would have something the right size that would work, no?
I just haven't looked yet. Anybody?
'09 Schwarze Blanche DuBois
