Bolt fell out
AmostThere
Bolt fell out
Post by AmostThere »
I may be the only one who didn't know but I guess I should have used threadlocker on the bolts which attach the SW-Motech brackets together. One out of the four was completely gone, fell out on the road somewhere. The others were all quite loose. On my bike they hold the topbox. I really don't want to think about the topbox flying off at freeway speed and destroying itself as well as the contents (DSLR, laptop, etc.) let alone causing some sort of injury to another motorist. I used Loctite blue, which is removeable, to prevent this from happening again.
2008 R1200R Granite Gray
lewellen
Donating Member #: 635
Re: Bolt fell out
Post by lewellen »
Glad you caught this before it went from "issue" to "problem"!
Also emphasizes the importance of the pre-ride walk-around and safety inspection... something I should do more myself, come to think of it....
Good roads,
- Lewellen180
Ves
Re: Bolt fell out
Post by Ves »
Or, lockwashers... or the "Nylock" nuts (uses nut and bolt?).
Dan-A
Donating Member #: 613
Re: Bolt fell out
Post by Dan-A »
Without blue loctite, life itself would be impossible. #-o
Dan-A
BMW MOA # 137114
BLOG: http://danzgarage.net
famousperson
Sextuple Lifer
Donating Member #: 599
Re: Bolt fell out
Post by famousperson »
Dan-A wrote:Without blue loctite, life itself would be impossible. #-o
That and duct tape.
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
spoon
Re: Bolt fell out
Post by spoon »
If you had only had a Harley Sportster - previously. You would know that XL means (Xtra Lock-Tite).
famousperson
Sextuple Lifer
Re: Bolt fell out
:badgrin: I did and I do!
'07 R1200R
Life Member #599
