Bolt fell out
AmostThere
Bolt fell out
I may be the only one who didn't know but I guess I should have used threadlocker on the bolts which attach the SW-Motech brackets together. One out of the four was completely gone, fell out on the road somewhere. The others were all quite loose. On my bike they hold the topbox. I really don't want to think about the topbox flying off at freeway speed and destroying itself as well as the contents (DSLR, laptop, etc.) let alone causing some sort of injury to another motorist. I used Loctite blue, which is removeable, to prevent this from happening again.
2008 R1200R Granite Gray
Re: Bolt fell out
Glad you caught this before it went from "issue" to "problem"!
Also emphasizes the importance of the pre-ride walk-around and safety inspection... something I should do more myself, come to think of it....
Good roads,
- Lewellen180
Good roads,
- Lewellen180
Re: Bolt fell out
Or, lockwashers... or the "Nylock" nuts (uses nut and bolt?).
Re: Bolt fell out
Without blue loctite, life itself would be impossible.
famousperson
- Sextuple Lifer
Re: Bolt fell out
That and duct tape.Dan-A wrote:Without blue loctite, life itself would be impossible.
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
Life Member #599
Re: Bolt fell out
If you had only had a Harley Sportster - previously. You would know that XL means (Xtra Lock-Tite).
famousperson
- Sextuple Lifer
