2000 R1100R rear turn signal replacement?
sprshrp
Post by sprshrp »
Hey there guys, new member here, was hoping someone might be able to help me out.
I recently lost my rear-left turn signal (the entire housing is gone, but the wiring is still there... hanging...), and was wondering if anyone had any suggestions on where to get a replacement? I checked Bob's BMW and A&S cycles, but was unable to find parts for my 2000 r1100r. I'm open to OEM or aftermarket, just want to get something installed!
Thanks for your help!
00zero
Re: 2000 R1100R rear turn signal replacement?
Post by 00zero »
Well, if they do not have it, check this
http://www.maxbmwmotorcycles.com/fiche/ ... spid=47947
philbytx
Post by philbytx »
For used (and some new) parts, try
www.beemerboneyard.com
Phil C.
2003 R1150RT "DaRTh"
2000 R1100R "LeRoy
philbytx wrote:For used (and some new) parts, try http://www.beemerboneyard.com
[/url]
They have lots of parts. ;)
sprshrp
Post by sprshrp »
thanks for the help, guys!
philbytx
Post by philbytx »
You will probably need to get the whole kit and caboodle....not cheap!
Just had to replace parts of my front turn signal. Fortunately, I found the most expensive part on the ground!
So, check out the parts you will need at this link:
http://www.webparts.com/diagram.php?btn ... g=63&fg=10
As you will see, they aren't cheap!
Phil C.
2000 R1100R "LeRoy
roadglide
Post by roadglide »
I had a crash that destroyed two of the turn signals and to replace the stock signals cost a bloody fortune (just the lens and housing for one directional is about fifty dollars not including the stem). I replaced all four with Baja Design turn signals. These look very close to stock but are a bit smaller however when mounted on my r1100r is un-noticeable. They are dot approved and very bright when activated
https://www.bajadesigns.com/NET/P-60419 ... rd%2c+Pair
roadglide
Post by roadglide »
Update on the Baja Turn signals. It turns out with the saddle bag rack the rears are about an inch too short the fronts look and work well. I was lucky and found a complete rear fender with stop light and directional’s. Stupid me I did not take in account the length of the studs I went on the overall length of the directional oopps
