Kisan Signal minder: Quirky or junk?
iowabeakster
Post by iowabeakster »
I just picked up a used (older one in black plastic case) signal minder.
I have read the all of the old posts regarding this thing. I have read of quirky behavior especially in high temps (from Herb, aka SJBMW) and others.
It seemed to work fine after installation: in the garage, key turned on, motor off. I headed off to work without a test ride. I was happy, seemed to work just fine.
So today, I took it for a ride. The thing was all wonky.
1. running lights were turned off, they turned themselves on
2. running lights were on, they would flicker
3. self canceling would happen after 0-20 seconds, apparently randomly, even with brake on (brake wire installed)
4. self cancelling would happen sometimes so fast that the flashers didn't even flash once
5. etc, etc, etc
I tried Every possible dip-switch setting, every "on the fly" setting, brake wire attached and not attached: Wonky, wonky, wonky, wonky
It was really hot. The weatherman keeps using words like "blistering" "oppressive" etc.
Anybody else have such troubles? Did I get a junker? Am I being punished for being such a cheap-skate?
Flame ON!
SLEDGE
Post by SLEDGE »
I've never had a problem with mine, had it for 1 1/2 years. Mine is in a shiney metal can. Bought mine on e bay was new.
Good Luck to Ypu
R.D
Oilhead
Post by Oilhead »
Same here. I have never had any problems.
2002 BMW R1150R
2004 Honda CBR600RR
2006 Kawasaki KLX250S
2008 Ducati Hypermotard
1996 Ducati 900SS
MikeCam
Centurion Moderator!
Donating Member #: 100
Post by MikeCam »
What you are describing is either heat related failure of the internals or prior owner sold a used model that has corrosion, moisture, shock damage from some incident (not suggesting abuse or seller omission, just heavy, debilitating prior use).
Best to write it off and get a new model. They do NOT all do that!
Boxer
Donating Member #: 2
Post by Boxer »
Mine has worked fine for 4 years now.
owldaddy
Post by owldaddy »
Mine has been flawless, I consider it to be an asset with one exception. When waiting at a left turn lane light, I have to hit the blinker several times, due to the self cancel. Now if they can figure out a way to make it realize that your not moving, and won't engage the cancel unless you are moving, it would be perfect.
Don
rogreenx
Post by rogreenx »
I have had the SignalMinder in three bikes so far without one problem.
rogreenx
r1150r
r1150rt
mcollect
Post by mcollect »
Owldaddy They thought of that. The wire that goes to the brake light keeps it from cancelling while waiting as long as the brake is on.
Michael
MG 78 LeMans
2002 R1150R
78 R100S
ruddy
Post by ruddy »
PM me with your email address, and I'll send you the instructions for the older model.
Rick
2003 R1150R: Silver
Lifetime Member #585
owldaddy
Post by owldaddy »
mcollet,
thanks for the info, I didn't hook that wire up, I thought it was just there to use the blinkers as brake lights also, and since I have the flashing LED brake lights, I just didn't think I needed that function. I will reconsider my needs.
Don
challey
Donating Member #: 365
Post by challey »
Second what most here have said about SM.
I've had mine for nearly 2 years and it has performed flawlessly.
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
TX2Step
Post by TX2Step »
I installed my SM-5 last year and it has been largely trouble-free. However, once in a while it takes 2 or 3 hits on the cancel button to get it to actually cancel. But it's intermittent and a minor annoyance. If it gets worse I'll contact Kisan.
Other than that, it's one of the best accessories that i have added.
Ron Jenson
Houston, TX
