Kisan Signal minder: Quirky or junk?
- iowabeakster
I just picked up a used (older one in black plastic case) signal minder.
I have read the all of the old posts regarding this thing. I have read of quirky behavior especially in high temps (from Herb, aka SJBMW) and others.
It seemed to work fine after installation: in the garage, key turned on, motor off. I headed off to work without a test ride. I was happy, seemed to work just fine.
So today, I took it for a ride. The thing was all wonky.
1. running lights were turned off, they turned themselves on
2. running lights were on, they would flicker
3. self canceling would happen after 0-20 seconds, apparently randomly, even with brake on (brake wire installed)
4. self cancelling would happen sometimes so fast that the flashers didn't even flash once
5. etc, etc, etc
I tried Every possible dip-switch setting, every "on the fly" setting, brake wire attached and not attached: Wonky, wonky, wonky, wonky
It was really hot. The weatherman keeps using words like "blistering" "oppressive" etc.
Anybody else have such troubles? Did I get a junker? Am I being punished for being such a cheap-skate?
Flame ON!
5. etc, etc, etc
Flame ON!
MikeCam
- Centurion Moderator!
What you are describing is either heat related failure of the internals or prior owner sold a used model that has corrosion, moisture, shock damage from some incident (not suggesting abuse or seller omission, just heavy, debilitating prior use).
Best to write it off and get a new model. They do NOT all do that!
Mine has been flawless, I consider it to be an asset with one exception. When waiting at a left turn lane light, I have to hit the blinker several times, due to the self cancel. Now if they can figure out a way to make it realize that your not moving, and won't engage the cancel unless you are moving, it would be perfect.
Don
Don
mcollet,
thanks for the info, I didn't hook that wire up, I thought it was just there to use the blinkers as brake lights also, and since I have the flashing LED brake lights, I just didn't think I needed that function. I will reconsider my needs.
Don
Don
I installed my SM-5 last year and it has been largely trouble-free. However, once in a while it takes 2 or 3 hits on the cancel button to get it to actually cancel. But it's intermittent and a minor annoyance. If it gets worse I'll contact Kisan.
Other than that, it's one of the best accessories that i have added.
Ron Jenson
Houston, TX
Houston, TX
