I don't have a trickle charger and don't want to have to buy a new battery.
I know I have read about jump starting the bike in this site before but I can't seen to find any topics.
Any of you guys have any
I've roll started mine a few times just for the fun of it...here's what I do.If I roll start do I have to have the bike in Gear and POP the Clutch like I do in my car or is there a DIFF.Way?
it's perfectly safe to use a car battery as long as the car isn't running. they're the same voltage.rearro wrote:Well I was asking about all that!! If I roll start do I have to have the bike in Gear and POP the Clutch like I do in my car or is there a DIFF.Way?
And Riceburner Is it safe to use a car Battery ??? And if so is there and easier way to get to the battery with out moving the gas tank??
I learn something new everytime I come on here! Thanks for that.P_Jensen wrote:... a positive lug under a small black cap (should have a + sign on it) by the power port / starter and a negative lug on the left cylinder in the area of the intake tube ...
the only issue I can see with running an Optimate on it on a permanent basis is that charging DOES cause the electrolyte to "bubble" (watch a fresh battery under charge one time). Obviously you're going to be losing "some" of that liquid to gas, of which "some" will go to atmosphere via the breather tube, and you've lost it.\Mike_Lea// wrote:I recently took my Rock for an annual service... The guys at BlueBell (my local dealership) said that the starter motor sounded a little 'lazy...', and they'd like to replace it under warranty - AUB warranty that came with the bike. I was most impressed by this !! Well done Blue Bell BMW Crewe (Cheshire, England)![]()
Getting to the point tho', we were talking about batteries as I'd wondered if the lazy or laboured starting was due to a dodgy battery. I mentioned that I'd now got it connected upto a battery conditioner, optimate to be precise.
The service rep. said that he'd experienced these things causing problems with batteries, specifically loosing electrolytes... I've no idea if this is true or if anyone else has experienced the same thing. I'd always thought that having a conditioner should extend the life of the battery.
Maybe he had a dodgy charger?? What d'ya Riceburner? The mechanical force seems strong with you![]()
M
I couldnt find these this morning.P_Jensen wrote:Your 04 should have two lugs on the left side by the power outlet, a positive lug under a small black cap (should have a + sign on it) by the power port / starter and a negative lug on the left cylinder in the area of the intake tube. Just connect the jumper cables to those points and no need to remove the fuel tank to get at the battery.
If you have a powerlet mounted on the starter cover you can charge the battery using that. Just get the right plug, like this (PPL-001):arbik wrote: I couldnt find these this morning.
Mine is an 04, and has a powerlet on the starter cover.
Where exactly are these positive /negative lugs?
-arbi
