GPS Power Source
GPS Power Source
Hello all, new guy here. I located the factory GPS Naviguessor power source on my K1200GT and spliced into it for CANBUS switched power. It was very easy to use, factory tie wrapped to a cross brace and sealed with a plastic cover. I'm sure the R1200R has the same plug under the tank, somewhere. I'm reluctant to pull the tank without looking at a service manual, which I don't yet have. Has anyone spotted the plug? Thanks in advance,
2007 R1200R Best bike ever ridden
2007 K1200GT fast fast fast
Very interesting. Can't help you but if you pull the tank I would realy apreciate it if you would take pictures of what you've done. There probably will be a connector somewhere as there is a special wiring harness available for GPS power suply(witch must plug into somewhere). I am planning on mounting a gps system(probably a Garmin Zumo) in the future somewhere next year for travelling abroad so any pictures would be very helpfull.
