Refilling ft. forks
Refilling ft. forks
Had to change a fork seal. What is the proper method of refilling the ft. forks? How much oil,bleeding the air out,est. Thanks
R.D
"Don't take life too seriosly,because you'll neve get out of it alive anyway."
ferroknight
Black Plastic Fork Tubes Cracked...
With 7000 miles on the clock, I guess it's time for me to change fork fluid while I install new caps.
John Carabillo
Sledge,
The service manual says:
Since there's no hydraulic damping circuit in them, a 5 or 10 weight synthetic oil should be fine for friction free movement.
EDIT: I've E-Mailed you a short note and the page from the service manual on fork dissassembly/assembly.
If you had it apart for a seal change, it takes 470cc forkoil per leg. The air space above the oil level does mimic an actual spring - - - as I found out when I removed the top forktube nut to change my mildly cracked top dust seals (the part that you see sliding up and down with the forktube).Note: No oil changes required during inspections: unit is
maintenance-free.
