Need Help! Disconnecting Heated Grip Wires
philm35
Post by philm35 »
I'm replacing my handlebars this weekend with Wunderlich Touring Comfort Bars. I've gotten to the point where I need to disconnect the heated grip connectors under the gas tank, and pull the wires out of the bars. I found the connectors, and they are different from those I've seen posted on this board. Instead of a 4-pin white Molex connector, there is a two-pin brown connector for each side.
My problems is, I can't get the pins out of the connectors. Any advice?
--Phil
2004 R1150RA (Silver) (in pieces, spread across the garage floor)
bimrluvr
Donating Member #: 429
Post by bimrluvr »
Can you post a pic?
#429 (in for life)
'06 Silver R1200RT
bimrluvr
Post by bimrluvr »
BTW, if you can't figure out how to undo the connectors, you could just cut them off and replace them with a different kind, like a couple Posilocks.
#429 (in for life)
'06 Silver R1200RT
beemerphile
Post by beemerphile »
There is a locking tang in there. Depress it with a very small precision screwdriver and withdraw the wire. There is no need to cut them off.
Lee
philm35
Post by philm35 »
I tried to find a locking tang in there, and pushed a tiny screwdriver in where I thought there ought to be one, but no luck. I was hoping to avoid chopping off the connectors and replacing them, but it looks like that's the route I'm going to have to take.
--Phil
SlideRuyle
Post by SlideRuyle »
be sure you are sticking the screwdriver in the right slot. I had trouble with one of them but eventually got it out.
One other piece of advice when pulling the wires back through the bars. Be careful not to pull too hard or you will pull the wires out loose from the grips. I had to buy a new left grip because I pulled the wire loose.
Slideruyle
Airman
Post by Airman »
Don't cut the wires. Here's the link to Kbasa's Ricky bar installation which will show you how to do this. Just think of it as releasing the wire connector from the plug.
http://www.smugmug.com/gallery/29459
philm35
Post by philm35 »
My connectors don't look like the ones on Ricky's page. Instead of a white 4-pin connector, I have two brown two-pin connectors, which are much smaller. I tried using the "Ricky" method of getting the pins out, but to no avail.
I ended up chopping them, and resoldering them back together.
I hope to get the bike buttoned up this evening, and have a test ride with my new bars. I'll give you a full report.
--Phil
