winterizing the R
ken k
winterizing the R
Post by ken k »
OK its time to start thinking about winterizing the R, Where can I get snow tires and chains????? :)
Seriously, does anyone use fuel stabilizer over the winter months?
I don't think I will totally mothball her over the winter, but I am sure my riding will be curtailed a bit by the cold.
ken k
Red 2003 R1150R
tor1150r
Post by tor1150r »
Ken,
I store mine at the dealer.
They ask that I drop the bike off with a full tank of gas (3/4 at least) and they add a stabilizer prior to storage. Not sure which one they use, I'm sure there are a number of brands.
When I pick it up in April I just run the tank to nearly empty and start fresh.
07 R12GS - Granite
04 R1150R - Black (sold)
Member #468
dano
Post by dano »
also, i have a 2004R. what battery tender should I buy?
life is what happens to us when we're busy making plans
lifetime member #470
jm1515
Triple Lifer
Re: winterizing the R
Post by jm1515 »
ken k wrote:OK its time to start thinking about winterizing the R, Where can I get snow tires and chains????? :)
ken k
This is what I will do...some time first week of Dec I imagine...I park my ride in an unheated garage.
Wash and dry the bike thoroughly...
New oil/filter only because it should need one by then...
Up on the centerstand on a waterproof tarp, as usual...
Fogging oil in the cylinders...
Sta-Bil in the gas tank/fuel lines...
BatteryTender as usual...
Plug up the air inlet and exhaust...
Cover w/ a clean sheet....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
tor1150r
Post by tor1150r »
dano wrote:also, i have a 2004R. what battery tender should I buy?
Dano,
I have the BMW 12v charger (for gel batteries). Works well and stops charging once the battery hits 100% (keeps a trickle)
Forget the model number, but there is only one that fits this description from BMW (Canada anyway). I paid ~125.00 C$ for it
BMW Generation II (Gel) Charger
07 R12GS - Granite
Member #468
BobFV1
Post by BobFV1 »
I will need fresh tires in November as I will be doing 200 - 500 mile weekends and track days straight through until Spring, when the real touring begins.
You guys are lucky you don't have to "Summerize" like we do, which involves getting on the bike and riding at least two hours North when it is 120 degrees here!
2006 R1200GS ADV "Five Charlie"
tor1150r
Post by tor1150r »
BobFV1 wrote:I will need fresh tires in November as I will be doing 200 - 500 mile weekends and track days straight through until Spring, when the real touring begins.
Rub it in Bob! :lol:
Just think of how much reading we'll get done over the winter!
07 R12GS - Granite
Member #468
tipstall
Donating Member #: 487
Post by tipstall »
I was told no Sta-Bil.
Silver '04 R1150R
#487
MooseR1100R
Winterizing the Rbike
Post by MooseR1100R »
Ken, just do what any rational Rbike rider from PA would do. Ride your R down here to Texas and store it with Darthrider, Dallara, myself or any of us and take a midwinter vacation and head to the Hill Country then ride like hell. The fuel injectors will stay clean with a dash of Sea Foam thrown in, the tires and oil will need to be changed. Then you'll be ready for the next riding season up north.
You can drink 'em pretty, but you can't drink 'em skinny.
BobFV1
Post by BobFV1 »
Hey - I have a guest room and two extra bikes - come on down about February....
fnfalman
Post by fnfalman »
I'm in Southern California, so the only winterization I do is to put on full leathers and ride like hell. :twisted:
Send me your bikes and I'll keep the engines warmed, turned over and lubed for you poor cold climate guys. :lol:
pjbmw
Fogging Oil?
Post by pjbmw »
How do you apply fogging oil?
dallara
Fogging oil...
Post by dallara »
Why, ride the bike through an oil fog, of course... :lol: :wink: :lol: :wink: :lol:
Seriously, fooging oil is an oil sprayed into the intakes of the cylinders while the engine is running to theoretically provide some lubrication for valve guides and seals, rings, cylinder bores, etc. You can easily do it with the air filter removed and spraying the oil into the airbox.
Hope this helps!
Dallara
The Kurch Man
Post by The Kurch Man »
I do a nice wash and clean, change oil and filter, use a regular battery tender (leaving the battery in the bike), I use (and always have) StaBil or Maxima fuel stabilizer. fill the tank up to the limit, put a few extra pounds in the tires, and park in in my garage with wood under the centerstand and tires, bike cover over it, and hug it every night.
Dennis
2004 R1150R
Eqyn Dad
Winterizing
Post by Eqyn Dad »
Why the need for wood under the center stand? If there is wood under the tires and the bike spends it's winter on the center stand is there any harm done?
arkline
Post by arkline »
The theory is that both tires should be lifted off the ground during long periods of storage so that they won't develop "flat spots". Probably more of a problem in a completely unheated storage area than one that has moderate temperature control...
arkline #27
not THE Ron Kline
"No matter where you go, there you are."
The Kurch Man
And the wood keeps the tires from the cold concrete should they be 'tempted' to tilt. It's a cold weather thing and I do not have a heated garage....
Dennis
2004 R1150R
Post by DJ Downunder »
I would suggest putting two Dyno-Tab's in the tank to stabilize the fuel during the stored time. http://www.dynotab.com/fuel.htm
