They ask that I drop the bike off with a full tank of gas (3/4 at least) and they add a stabilizer prior to storage. Not sure which one they use, I'm sure there are a number of brands.
When I pick it up in April I just run the tank to nearly empty and start fresh.
07 R12GS - Granite
04 R1150R - Black (sold)
Member #468
ken k wrote:OK its time to start thinking about winterizing the R, Where can I get snow tires and chains?????
Seriously, does anyone use fuel stabilizer over the winter months?
I don't think I will totally mothball her over the winter, but I am sure my riding will be curtailed a bit by the cold.
ken k
This is what I will do...some time first week of Dec I imagine...I park my ride in an unheated garage.
Wash and dry the bike thoroughly...
New oil/filter only because it should need one by then...
Up on the centerstand on a waterproof tarp, as usual...
Fogging oil in the cylinders...
Sta-Bil in the gas tank/fuel lines...
BatteryTender as usual...
Plug up the air inlet and exhaust...
Cover w/ a clean sheet....
j magda
TripleLifer Member 454
Deep in the OH wasteland...
I will need fresh tires in November as I will be doing 200 - 500 mile weekends and track days straight through until Spring, when the real touring begins.
You guys are lucky you don't have to "Summerize" like we do, which involves getting on the bike and riding at least two hours North when it is 120 degrees here!
BobFV1 wrote:I will need fresh tires in November as I will be doing 200 - 500 mile weekends and track days straight through until Spring, when the real touring begins.
Rub it in Bob!
Just think of how much reading we'll get done over the winter!
07 R12GS - Granite
Member #468
Ken, just do what any rational Rbike rider from PA would do. Ride your R down here to Texas and store it with Darthrider, Dallara, myself or any of us and take a midwinter vacation and head to the Hill Country then ride like hell. The fuel injectors will stay clean with a dash of Sea Foam thrown in, the tires and oil will need to be changed. Then you'll be ready for the next riding season up north.
You can drink 'em pretty, but you can't drink 'em skinny.
Rub it in Bob!
Hey - I have a guest room and two extra bikes - come on down about February....
Why, ride the bike through an oil fog, of course...
Seriously, fooging oil is an oil sprayed into the intakes of the cylinders while the engine is running to theoretically provide some lubrication for valve guides and seals, rings, cylinder bores, etc. You can easily do it with the air filter removed and spraying the oil into the airbox.
I do a nice wash and clean, change oil and filter, use a regular battery tender (leaving the battery in the bike), I use (and always have) StaBil or Maxima fuel stabilizer. fill the tank up to the limit, put a few extra pounds in the tires, and park in in my garage with wood under the centerstand and tires, bike cover over it, and hug it every night.
Why the need for wood under the center stand? If there is wood under the tires and the bike spends it's winter on the center stand is there any harm done?
The theory is that both tires should be lifted off the ground during long periods of storage so that they won't develop "flat spots". Probably more of a problem in a completely unheated storage area than one that has moderate temperature control...
