Hi guys,
My beloved convinced me to buy an ABS model (safety, concern for well being etc)
Is it normal that when the engine isn't running there are no brakes. Parked on a hill, I dropped the bike into neutral to start and found myself rolling backwards. Grabbed a handful of brake....NADA
Surely this isn't the default option.
Soliton
ABS- Engine off, no brakes....normal??
Re: ABS- Engine off, no brakes....normal??
With the ignition off, it does require LOTS more effort to work the brakes, but there should be brakes.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
What year?
But like John said it takes a lot more pressure with no engine as the iABS system uses an electric motor driven hydraulic pump to power the brakes. Like power brakes on a car.
R4R&R wrote:With the ignition off, it does require LOTS more effort to work the brakes, but there should be brakes.
this^ you SHOULD have brakes. but I found it was not reliable.
Mine is a 2002. I Removed the ABS.
I agree, the brakes do work, but more effort is required without the engine running.
