ABS- Engine off, no brakes....normal??
Soliton
Post by Soliton »
Hi guys,
My beloved convinced me to buy an ABS model (safety, concern for well being etc)
Is it normal that when the engine isn't running there are no brakes. Parked on a hill, I dropped the bike into neutral to start and found myself rolling backwards. Grabbed a handful of brake....NADA
Surely this isn't the default option.
Soliton
R4R&R
Donating Member #: 293
Re: ABS- Engine off, no brakes....normal??
Post by R4R&R »
With the ignition off, it does require LOTS more effort to work the brakes, but there should be brakes.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
What year?
But like John said it takes a lot more pressure with no engine as the iABS system uses an electric motor driven hydraulic pump to power the brakes. Like power brakes on a car.
peels
Post by peels »
R4R&R wrote:With the ignition off, it does require LOTS more effort to work the brakes, but there should be brakes.
this^ you SHOULD have brakes. but I found it was not reliable.
Mine is a 2002. I Removed the ABS.
gregor
Post by gregor »
I agree, the brakes do work, but more effort is required without the engine running.
