Accessory connection
southerndreamer
Post by southerndreamer »
Hi all, just scored a very nice 2005 1150R in Yellow and ?????? I want to add an accessory socket and think I have found the correct wires/plug just above the Solenoid but can't find any details as to what colour these should be if they are the correct ones. Those in question are Brown and Red/white with a two pin connector attached. I would be grateful if someone could confirm this is the correct wire.
opposedcyljunkie
Re: Accessory connection
Post by opposedcyljunkie »
Doesn't your R have one on the starter cover?
southerndreamer wrote:Hi all, just scored a very nice 2005 1150R in Yellow and ?????? I want to add an accessory socket and think I have found the correct wires/plug just above the Solenoid but can't find any details as to what colour these should be if they are the correct ones. Those in question are Brown and Red/white with a two pin connector attached. I would be grateful if someone could confirm this is the correct wire.
Yes, the red/white stripe is Fuse3 power for socket.
That connector plugs into the socket assembly:
61 13 1 391 630 PLUG-IN SOCKET
01 29 7 663 960 INSTALL.INSTRUCTIONS, PLUG-IN SOCKET
southerndreamer
Thanks for the prompt replies. The side cover does have a hole with a plug where the socket will go when I get one.
