Not fitted new plugs to R1150R yet. New NGKs in the post.
Hope there is no bother getting the old ones out as they are possibly the originals at 5 YO.
What is the tightening procedure?
On my old K75 advice was finger tight then 1/2 turn, or something like that.
Will put a dab of copper grease on threads as well.
Fitting New Spark Plugs
Re: Fitting New Spark Plugs
Same again. I will soon see if the tightening advice was correct.
A must though is to thoroughly clean around the plugs before attempting to remove them. A lot of grit was lurking in there and I used a bottle brush plus plenty of engine cleaner.
Oh - also - I slather the coil-caps with silicon grease - it seems to help prevent them corroding and failing. (makes them a little easier to remove too)
I don't think they're really built to withstand the moisture they get exposed to.
Fitting New Spark Plugs & Air Cleaner
Came out easily but plugs and washers were a bit rusty. Cleaned up heads carefully before putting the new NGK plugs in. Noticed the paint was flaking from the cam chain housings so a quick scrape and some Hammerite smooth silver has sorted that pro tem. New paper air cleaner went in OK after I carefully lined the lugs up.
