Motolight install question...
unibober
Post by unibober »
Have a hopefully simple question for you guys. While Im waiting for my my new fuel QCs, Ive decided to reinstall the Motolights that the PO had removed. Tank is removed and the wiring has been laid out for the install and am happy with where it will go. My problem is....the wire that gets wired to a has a two slot fuse plug like the here called an ATC-PLUG http://www.sherco-auto.com/electacc.htm. Just wondering what plug I should use. It had a 4 amp plug in it, but the way the foam above the fuses is cut, it seems not to work. I can provide pics but maybe someone has a easy answer. I know, whats that!
unibober
Re: Motolight install question...
Post by unibober »
Meant to say...wire that gets wired to a switched fuse...
rdsmith3
Donating Member #: 74
Post by rdsmith3 »
I think I used the heated grip circuit. It is not a mission-critical circuit if something goes wrong, and it is turned off when you crank the engine.
Bob
2002 Atlanta Blue
Lifetime Member #74
unibober
Post by unibober »
That is what Ill use then. Its a 7.5 amp from what I can tell. Cant find a fuse diagram on the bike. Kinda weird. Not one in the Clymers either.
unibober
Post by unibober »
Make that 10amp. Could someone verify that the 7th fuse from the port side is indeed the heated grips and that it infact, should be 10 amp. Kinda confused.
rdsmith3
Post by rdsmith3 »
Bob
2002 Atlanta Blue
Lifetime Member #74
