Motolight install question...
Have a hopefully simple question for you guys. While Im waiting for my my new fuel QCs, Ive decided to reinstall the Motolights that the PO had removed. Tank is removed and the wiring has been laid out for the install and am happy with where it will go. My problem is....the wire that gets wired to a has a two slot fuse plug like the here called an ATC-PLUG http://www.sherco-auto.com/electacc.htm. Just wondering what plug I should use. It had a 4 amp plug in it, but the way the foam above the fuses is cut, it seems not to work. I can provide pics but maybe someone has a easy answer. I know, whats that!
Re: Motolight install question...
Meant to say...wire that gets wired to a switched fuse...
I think I used the heated grip circuit. It is not a mission-critical circuit if something goes wrong, and it is turned off when you crank the engine.
2002 Atlanta Blue
Lifetime Member #74
2002 Atlanta Blue
Lifetime Member #74
That is what Ill use then. Its a 7.5 amp from what I can tell. Cant find a fuse diagram on the bike. Kinda weird. Not one in the Clymers either.
Make that 10amp. Could someone verify that the 7th fuse from the port side is indeed the heated grips and that it infact, should be 10 amp. Kinda confused.
2002 Atlanta Blue
Lifetime Member #74
2002 Atlanta Blue
Lifetime Member #74
