Will Vario risers deal with wrist pain?
Re: Will Vario risers deal with wrist pain?
Update- I received the Wunderlich Vario risers and they installed easily on my bike. After about a month of riding around with the risers in place my wrist pain is GONE! The slight adjustment in height, and I assume angle, has completely remedied the bad pain I used to get with the stock setup. Hope this helps anyone with the same problem.
Blue 10' R1200R
Triumph Sprint ST (traded for)
ContraMoto
No need to install longer throttle or brake cables?bmwk100 wrote:Update- I received the Wunderlich Vario risers and they installed easily on my bike.
'07 R12R Black w/stripes
North Cali
North Cali
Negative. Very simple install.ContraMoto wrote:No need to install longer throttle or brake cables?bmwk100 wrote:Update- I received the Wunderlich Vario risers and they installed easily on my bike.
Blue 10' R1200R
CupOHemlock
I cannot be much help here. I just switched from a S1000RR to the R12... for me it is like sitting in an easy chair sipping good scotch by comparison
Good luck in any case. Be comfortable!
Thunder Grey 2010 S1000RR "The Beast" (sold)
Metallic Red Apple 2011 R1200R
Member #494
Member #494
