Does anyone know what this thing is?
rsperko
Post by rsperko »
There is a wire coming out from under my gas tank that ends in what looks like a little light (or light sensor?). Does anyone know what this is a part of? I will eventually take the tank off, but hope to own the bike at least a week before I do that.
Thank you,
-Rick
'02 BMW R1150R
'06 RE Bullet Classic Iron
'63 VW Beetle Ragtop
'66 Chris-Craft Cavalier Cutlass
owldaddy
Re: Does anyone know what this thing is?
Post by owldaddy »
Do you have an "Autoswitch" installed? It is kind of hard to tell, due to the focus, but it looks like a status light for an Autoswitch, I use one to operate my running lamps. When the lamps are lit, that LED lights up.
jas
Post by jas »
That looks like the light sensor for a headlight modulator.
2004 Roc.
johnnyjs1
Donating Member #: 607
Post by johnnyjs1 »
Yup....guessing autswitch as well
09 Someting??
Lifer 607
rsperko
Post by rsperko »
Wow, didn't know auto switches existed. I will see if I can figure out what it is doing. The bike does have a headlight modulator installed. I am still figuring out how that works. Hold the headlight button seems to toggle it. I have covered this thing to see if it was a light sensor for the modulator, but it didn't do anything.
Now I am off to read info on auto-switches. I may try to contact the PO, he left his insurance info in the bike, so I think I know his name.
Thanks for the info,
-Rick
'02 BMW R1150R
Ol' Jeffers
Post by Ol' Jeffers »
I have a redundant LED on my bike as well. It was the indicator LED for the alarm system that was once fitted.
OJ........everybody's pal!!
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
It's kind of hard to see exactly what that is, but if it flashes red when you turn on the key, it might be an Autoswitch indicator LED. To test it, hold down the turn signal indicator "CANCEL" switch for ~ 2 seconds and it should flash red than quickly change to green. This is how you would turn on whatever it controls (aux. lights, etc.). Press and hold the "CANCEL" switch again to shut it off, or simply turn off the ignition switch.
ADIOS!
taosports
Post by taosports »
That is the sensor for the Kisan Headlight Modulator. I have one and it looks identical to yours. Check out the following link to determine where to put it and how to set it up.
https://www.kisantech.com/index.php?cat_id=2
