Oil Filter Wrench
davidh8462
Oil Filter Wrench
Post by davidh8462 »
Does any one no if there is a difference between the BMW oil filter wrench priced at $30.00 as compared to the an aftermarket oil filter wrench for about $5. The $30.00 oil filter wrench by BMW looks "gold" in color, Just wondering if it is made better or has a more precise fit on a oil filter. All comments welcomed.
-Dave
Silver 04 R1150R
R1150Rclean
Re: Oil Filter Wrench
Post by R1150Rclean »
davidh8462 wrote:Does any one no if there is a difference between the BMW oil filter wrench priced at $30.00 as compared to the an aftermarket oil filter wrench for about $5. The $30.00 oil filter wrench by BMW looks "gold" in color, Just wondering if it is made better or has a more precise fit on a oil filter. All comments welcomed.
-Dave
I got the BMW aluminum wrench for $24 from the dealer, the after market ones for the R1150R are stamped metal, they should work the same.
macx
Post by macx »
I bought a plastic one at O'Reilly's, took a filter and fitted it to make sure I got the right one from a selection
of several sizes, if I recall just a few $ - maybe $5 or so? There was a little lip on the outside on the open end I took off, can't remember if I used a file or a grinder. No major problem, sure worth the price diff.
Has worked fine for a year. Has a 3/8" drive square hole for a ratchet.
kantuckid
Post by kantuckid »
You could take the "gold" BMW wrench and wear it for bling? The parts store one offers zero class! :lol:
Phang
Donating Member #: 707
Post by Phang »
Not only bling but it binnnngs as well.
http://www.youtube.com/watch?v=Ut6pObe4OcQ
I believe the BMW filter wrench is made by Hazet (pn# 2169) at approximately €14 each. Any thin wall filter wrench with 74mm across the flats and 14 flutes will do the job. Personally I am using a KTC without a problem.
Hazet 2169 on the left, KTC AVSA-074 on the right
jas
Post by jas »
You could go the KN-163 route and use a socket or wrench.
I pick them up from Happy Trails, a local shop, for about $10.00 ea.
2004 Roc.
You can get a set of three different fitments from Harbor Freight for about $10, or if you want a single one it can be sorced at Wally Mart also for about $5.
duckdave
Donating Member #: 580
Post by duckdave »
I got one of the cheapo ones from Wal-mart; spent about and hour or more grinding it down all even and neat. It cracked the first time I used it, so I went and got the expensive one... there being no oil in my m/c by this point. It has served me well for a half dozen changes since, wipes clean with a rag, and still shines (well, it's sort of silver colored).
So much to do, so little time.
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
TicTac50
Donating Member #: 586
Post by TicTac50 »
Since I am using AmsOil filters, I got the filter wrench from AmsOil, for 3 bucks.
It required 3/8 drive, so I plugged it with the flat head bolt and and secured it with two 17mm nuts.
Worked well for me for the last 7 years.
If I would own a business of changing the oil, I would spend 50 dollars on the wrench, no problem.
For occasional use, 3 dollars cup will do the job fine.
It takes a couple of minutes to take the filter off and less than a minute with the good golden wrench.
I really do not make $47.00 in 2 minutes. :oops:
What ever you choose, will take the filter off, at least couple of times. :-k
Good Luck.
Lifetime Member #586
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
Over 70,000 miles (two R's) AC Delco filter and el cheapo filter wrench. No problems.
BMWEW1
Post by BMWEW1 »
I use one of these $10 3 prong wrenches from Autozone that adapt to the size of the filter, it fits a bit tight up in the filter area but has worked so far for me.
http://www.autozone.com/autozone/catalo ... ndName=OEM
'03 R1150R, '05 Ural Patrol, '05 KLR650....Wash, DC
