Oil Filter Wrench
davidh8462
Oil Filter Wrench
Does any one no if there is a difference between the BMW oil filter wrench priced at $30.00 as compared to the an aftermarket oil filter wrench for about $5. The $30.00 oil filter wrench by BMW looks "gold" in color, Just wondering if it is made better or has a more precise fit on a oil filter. All comments welcomed.
-Dave
-Dave
Silver 04 R1150R
R1150Rclean
Re: Oil Filter Wrench
I got the BMW aluminum wrench for $24 from the dealer, the after market ones for the R1150R are stamped metal, they should work the same.davidh8462 wrote:Does any one no if there is a difference between the BMW oil filter wrench priced at $30.00 as compared to the an aftermarket oil filter wrench for about $5. The $30.00 oil filter wrench by BMW looks "gold" in color, Just wondering if it is made better or has a more precise fit on a oil filter. All comments welcomed.
-Dave
I bought a plastic one at O'Reilly's, took a filter and fitted it to make sure I got the right one from a selection
of several sizes, if I recall just a few $ - maybe $5 or so? There was a little lip on the outside on the open end I took off, can't remember if I used a file or a grinder. No major problem, sure worth the price diff.
Has worked fine for a year. Has a 3/8" drive square hole for a ratchet.
You could take the "gold" BMW wrench and wear it for bling? The parts store one offers zero class!
Not only bling but it binnnngs as well.
http://www.youtube.com/watch?v=Ut6pObe4OcQ
I believe the BMW filter wrench is made by Hazet (pn# 2169) at approximately €14 each. Any thin wall filter wrench with 74mm across the flats and 14 flutes will do the job. Personally I am using a KTC without a problem.
Hazet 2169 on the left, KTC AVSA-074 on the right
You could go the KN-163 route and use a socket or wrench.
I pick them up from Happy Trails, a local shop, for about $10.00 ea.
2004 Roc.
You can get a set of three different fitments from Harbor Freight for about $10, or if you want a single one it can be sorced at Wally Mart also for about $5.
I got one of the cheapo ones from Wal-mart; spent about and hour or more grinding it down all even and neat. It cracked the first time I used it, so I went and got the expensive one... there being no oil in my m/c by this point. It has served me well for a half dozen changes since, wipes clean with a rag, and still shines (well, it's sort of silver colored).
So much to do, so little time.
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
Since I am using AmsOil filters, I got the filter wrench from AmsOil, for 3 bucks.
It required 3/8 drive, so I plugged it with the flat head bolt and and secured it with two 17mm nuts.
Worked well for me for the last 7 years.
If I would own a business of changing the oil, I would spend 50 dollars on the wrench, no problem.
For occasional use, 3 dollars cup will do the job fine.
It takes a couple of minutes to take the filter off and less than a minute with the good golden wrench.
I really do not make $47.00 in 2 minutes.
What ever you choose, will take the filter off, at least couple of times.
Good Luck.
Good Luck.
Lifetime Member #586
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
2004 R1150 ABS
2003 F650 CSA
Over 70,000 miles (two R's) AC Delco filter and el cheapo filter wrench. No problems.
I use one of these $10 3 prong wrenches from Autozone that adapt to the size of the filter, it fits a bit tight up in the filter area but has worked so far for me.
http://www.autozone.com/autozone/catalo ... ndName=OEM
'03 R1150R, '05 Ural Patrol, '05 KLR650....Wash, DC
