front wheel removal
front wheel removal
Can anyone point me to some directions for removing the front wheel?
I just changed the rear tire but the front is giving me a problem.
thanks,
Ryan
thanks,
Ryan
Re: front wheel removal
It is shown in the Owner's Manual.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
'17 F800GSA
'04 R1150R
Biff's R wrote:It is shown in the Owner's Manual.
I don't have one.
Take the calipers off, remove the 4 lug nuts, whalla!! Done. Although I did have a bit of trouble getting the calipers back on the wheel, a bit of fanagaling and swearing, and it was back on
09 Someting??
Lifer 607
09 Someting??
Lifer 607
johnnyjs1 wrote:Take the calipers off, remove the 4 lug nuts, whalla!! Done. Although I did have a bit of trouble getting the calipers back on the wheel, a bit of fanagaling and swearing, and it was back on
Thanks Johnny. I got the rear wheel off, no problem. Took about a 1/2 hour to change the tire from start to finish. Then I started on the front. Took the calipers off, loosened the right pinch bolt, took out the left side axle bolt and then went to loosen the left pinch bolt and it is stripped. Kind of brought my project to a halt for the evening. While I was sitting there staring at it I realized that I'm not sure how to remove the axle. Left to right or right to left? BFH? LFH? Block of wood? Screw driver? I don't know.
Thanks,
Ryan
awagnon wrote:
Perfect. Thanks!
- iowabeakster
You're almost home (except the stripped bolt).
Get both pinch bolts loose. Stick a screwdriver in the holes on the Right hand side of axle...and twist and pull.
Notice: Speedometer drive unit (on left) and spacer(on right)
A very light greasing of the axle will keep it easy to remove next time.
edit-Al beat me...Look at picture above.
Thanks for the tips.
Yeah, the stripped bolt is a bit of an obstacle at this point. I want to wait and see if I can get a replacement at the shop tomorrow before I try to get it out. Plan on trying my luck with an ez out. Any other suggestions?
I, just removed both front and rear wheels because I needed some new tires Question? what type of grease and how much do I use on the front axle when I reinstall the front wheel?
Thanks, Jerry
Thanks, Jerry
BLK 03 R1150R
Anything will work fine. It isn't critical. Just a light coating of whatever you have just so you can slide it off in the future.hirschg wrote:Question? what type of grease and how much do I use on the front axle when I reinstall the front wheel?
When in doubt, apply heat. You never know when Locktite was used on a bolt. Also, heating seems to expand the metal around the bolt enough to loosen it, even without Locktite.Plan on trying my luck with an ez out. Any other suggestions?
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
Ogden, Utah
2002 R1150RT
2004 R 1150GS
Thanks everyone.
Got the bolt out with a bolt remover. Sears had them on sale for $9.99 for a set. There is just enough of the bolt head sticking out to get a bite on. Tapped it on with a hammer and it turned right out. Worked great.
The front tire was harder to put on than the rear. It was a little easier the second time, after I took it off to turn it around.
Thanks,
Ryan
Thanks,
Ryan
Keep Your Stick On the Ice.
Listen to Me at kaxe.org
bransan wrote:DUHOH! Did that myself on the rear first time.
Yep, lesson learned. I bet it doesn't happen again.
