front wheel removal
rpd1
front wheel removal
Post by rpd1 »
Can anyone point me to some directions for removing the front wheel?
I just changed the rear tire but the front is giving me a problem.
thanks,
Ryan
Biff's R
Donating Member #: 289
Re: front wheel removal
Post by Biff's R »
It is shown in the Owner's Manual.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
rpd1
Post by rpd1 »
Biff's R wrote:It is shown in the Owner's Manual.
I don't have one.
johnnyjs1
Donating Member #: 607
Post by johnnyjs1 »
Take the calipers off, remove the 4 lug nuts, whalla!! Done. Although I did have a bit of trouble getting the calipers back on the wheel, a bit of fanagaling and swearing, and it was back on :oops:
09 Someting??
Lifer 607
rpd1
Post by rpd1 »
johnnyjs1 wrote:Take the calipers off, remove the 4 lug nuts, whalla!! Done. Although I did have a bit of trouble getting the calipers back on the wheel, a bit of fanagaling and swearing, and it was back on :oops:
Thanks Johnny. I got the rear wheel off, no problem. Took about a 1/2 hour to change the tire from start to finish. Then I started on the front. Took the calipers off, loosened the right pinch bolt, took out the left side axle bolt and then went to loosen the left pinch bolt and it is stripped. Kind of brought my project to a halt for the evening. While I was sitting there staring at it I realized that I'm not sure how to remove the axle. Left to right or right to left? BFH? LFH? Block of wood? Screw driver? I don't know.
Thanks,
Ryan
awagnon
Post by awagnon »
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
rpd1
Post by rpd1 »
awagnon wrote:Image
Perfect. Thanks! :smt023
iowabeakster
Post by iowabeakster »
You're almost home (except the stripped bolt).
Get both pinch bolts loose. Stick a screwdriver in the holes on the Right hand side of axle...and twist and pull.
Notice: Speedometer drive unit (on left) and spacer(on right)
A very light greasing of the axle will keep it easy to remove next time.
edit-Al beat me...Look at picture above. :D
rpd1
Post by rpd1 »
Thanks for the tips.
Yeah, the stripped bolt is a bit of an obstacle at this point. I want to wait and see if I can get a replacement at the shop tomorrow before I try to get it out. Plan on trying my luck with an ez out. Any other suggestions?
hirschg
Post by hirschg »
I, just removed both front and rear wheels because I needed some new tires Question? what type of grease and how much do I use on the front axle when I reinstall the front wheel?
Thanks, Jerry
BLK 03 R1150R
awagnon
Post by awagnon »
hirschg wrote:Question? what type of grease and how much do I use on the front axle when I reinstall the front wheel?
Anything will work fine. It isn't critical. Just a light coating of whatever you have just so you can slide it off in the future.
When in doubt, apply heat. You never know when Locktite was used on a bolt. Also, heating seems to expand the metal around the bolt enough to loosen it, even without Locktite.
Al
Ogden, Utah
2002 R1150RT
2004 R 1150GS
rpd1
Post by rpd1 »
Thanks everyone.
Got the bolt out with a bolt remover. Sears had them on sale for $9.99 for a set. There is just enough of the bolt head sticking out to get a bite on. Tapped it on with a hammer and it turned right out. Worked great.
The front tire was harder to put on than the rear. It was a little easier the second time, after I took it off to turn it around.
Thanks,
Ryan
bransan
Post by bransan »
#-o DUHOH! Did that myself on the rear first time. #-o
Keep Your Stick On the Ice.
Listen to Me at kaxe.org
rpd1
Post by rpd1 »
bransan wrote:#-o DUHOH! Did that myself on the rear first time. #-o
Yep, lesson learned. I bet it doesn't happen again.
