Getting to the battery...?
How do I get to the battery on my R1150R?
I want to trickle charge it. I can see the battery top, under the fuel tank, but my fingers are too fat to be able to clip the charger on the positive terminal.
Ideas gratefully received.
davidh8462
Don't be scared of removing your tank.
Removing the tank is not a difficult procedure: they are 13 screws to undo using the smaller of the 2 tork keys in the toolkit and 1 using the larger one. Apart from that there is one snap-fit electrical connector to pull-apart and the QDs to release.
The tank then lifts off in a backward direction.
Once you have tackled it once, it takes 10-15 minutes to do.
The only thing to be careful of, as already mentioned, is the QDs (quick disconnects). Removing the tank is also an ideal time to check the condition of the fuel lines and also to consider 'upgrading' the QDs to the Omega ones or similar.
Life Member #551
02 Blue BMW R1150R non-ABS
davidh8462
Minimal...Unless you crack the QD. But I've had my tank off at least 10 times or more and I have been very careful...and they have never cracked on me.in removing the quick release connects for the fuel lines...do I have to worry about gas coming out?
Put a little silicone grease on the o-ring before you try to slide them together and they should go fine.
- Swissbiker
