Getting to the battery...?
pvdl
Post by pvdl »
How do I get to the battery on my R1150R?
I want to trickle charge it. I can see the battery top, under the fuel tank, but my fingers are too fat to be able to clip the charger on the positive terminal.
Ideas gratefully received.
maduko
Donating Member #: 735
Post by maduko »
Remove the bolt at the aft end of the fuel tank and you can raise it up.
Or buy an accessory socket plug and wire that on to your trickle charger. Much easier.
allanj255
Post by allanj255 »
If you have an accessory socket fitted you can charge your battery via this. If not they are easy to fit, the wiring is already there under the starter motor cover and it is a simple plug in fit
Allan
2003 R1150R Twin Spark, (Black - the fastest colour)
challey
Donating Member #: 365
Post by challey »
My vote is to install the accessory socket and use that. Though it's pretty easy to do what Maduko suggested and just raise the tank to get to the battery, installing the socket takes less than an hour and pays off in the long run.
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
davidh8462
Post by davidh8462 »
don't you have to remove the side panels and oil coolers ..to get the tank to lift up so that you can get to the battery?
acejones
Post by acejones »
Thats the best way. Be careful of the fuel line connectors and those tiny o-rings.
MartinW
Post by MartinW »
Don't be scared of removing your tank.
Removing the tank is not a difficult procedure: they are 13 screws to undo using the smaller of the 2 tork keys in the toolkit and 1 using the larger one. Apart from that there is one snap-fit electrical connector to pull-apart and the QDs to release.
The tank then lifts off in a backward direction.
Once you have tackled it once, it takes 10-15 minutes to do.
The only thing to be careful of, as already mentioned, is the QDs (quick disconnects). Removing the tank is also an ideal time to check the condition of the fuel lines and also to consider 'upgrading' the QDs to the Omega ones or similar.
Life Member #551
02 Blue BMW R1150R non-ABS
davidh8462
in removing the quick release connects for the fuel lines...do I have to worry about gas coming out?
Boxer
Donating Member #: 2
Post by Boxer »
Minimal...Unless you crack the QD. But I've had my tank off at least 10 times or more and I have been very careful...and they have never cracked on me.
Put a little silicone grease on the o-ring before you try to slide them together and they should go fine.
Swissbiker
Post by Swissbiker »
...and don't forget to put a piece of towel between steering head and fueltank. Otherwise you'll scratch or dent the fuel tank once you lift it up...
:wink:
Ciao
Vito
