Bar Backs?
Bar Backs?
I thinking of buying a set of bar backs for my R. Looking at the
moto-tecniques. Two sizes available both have 1'' rise however different set backs. What seems to be the setback most riders perfer 5/8'' or
1 1/4''?
Thanks ..........Jerry
1 1/4''?
BLK 03 R1150R
danstl
- Double Lifer
Bar Backs
The best thing to do is to sit on your bike and assume what you think is a comfortable position. Have someone measure how much back/up your hands are from normal and then look for bar backs that give you that position.
Another option, and the one I most preferred on my last R1150R was the Touring Wellness bars from Wunderlich. When these are mounted, they look stock. The bar backs restrict the use of some tank bags and other things which I did not like. I have Verholen's on my R1200R and they make it impossible to use a tank bag. I will be switching to a Touring Wellness bar when I get time.
- priapismic
danstl is absolutely correct.
http://www.eurotechmotorsports.com/form ... 2%2000%2D1 With just a little cables and wires tweaking you will have the best riding position. And the Touring Wellness bars from Wunderlich will make your bike a real tourer.
With the setup like that, the Harley guys will be jealous.
At least my brother is jealous. Anybody wants to buy a V-Rod with a very little mileage
Good Luck.
I found that the best ones for me ware the one from:The best thing to do is to sit on your bike and assume what you think is a comfortable position. Have someone measure how much back/up your hands are from normal and then look for bar backs that give you that position.
Good Luck.
Lifetime Member #586
2002 R1150R
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
2002 R1150R
2004 R1150 ABS
2003 F650 CSA
- priapismic
Re: Bar Backs
danstl wrote:The best thing to do is to sit on your bike and assume what you think is a comfortable position. Have someone measure how much back/up your hands are from normal and then look for bar backs that give you that position.
Here's something you can do yourself: sit on the bike, hands on the grips. Now, lift your hands off of the grips, make a fist, then rest your knuckles back on the grips. Obviously you can't ride like that, but that will give you an estimation of how much rise you'll get from bar-backs. Your back will be a little straighter, your shoulders a bit higher, there will be slightly less pressure on your wrists. That's about the improvement you can expect from bar-backs. If you think that will be more comfortable for you, go for it. If not, keep looking for different bars.
barbacks off
I installed the moto techniques and rode with them for about a year. I then removed them and preferred the ride without. You need to try them for awhile to make the decsion though.
Jamie
