Buzzing?
Buzzing?
Looking for opinions...
My 04 RR with almost 12,000 mi has developed a problem?
Both up and down the tach, at exactly 3500 RPM, the front end ( or engine? )
has developed a high pitched buzzing sound. It is only at this RPM, not 3400, not 3600. I live in New England commuting daily to work and it just started a couple of days ago.
The only thing I have done recently was to change the oil and filter at 10,000 miles.
Thoughts anyone?
Tom
Thoughts anyone?
Tom
I went through this very thing over the summer.
I found the bolt that holds the igntion switch had come loose and the wave washer on ther bolt was buzzing. You have to look behind the headlight and up under the igntion switch to see the bolt,it is a 6mm allen head bolt. My bolt had backed out about 4 mm by the time I found it and the noise was awfull.
pjbmw,
The buzz is heard from the front, but not felt, either through the grips or elsewhere.
The more I experience it, the more I become convinced that it is not coming from the engine but must be something on the front end.
I think that I will have to do a thorough inspection of the front to see if anything is loose or missing.
Thanks for the input.
Tom
Tom
Tom -
Get up to whatever speed/rpm produces the most vibes.
Pull in the clutch lever and roll off the gas.
If the vibes continue they are not in the engine or driveline "upstream" of the clutch, they are in the driveline, wheels, etc.
Try gently applying the brakes individually.
Be systematic and this may help narrow it down.
Dave
#226
#226
Hope this helps :)
Tom
I remember a thread a few months back (on the old board I think) which was very similar to this.
If memory serves me correctly, the problem was tracked down to the clock. There was maybe... a lose back or something like that. Don't remember whose issue it was, but it was causing him a hell of a lot of concern and when pointed out... it was very easy to solve.
Hope this helps
Hope this helps
glad to be of assistance
bmwkid
hope i was of some assistance
I had a low rpm buzz. Located it to the tank area.
The filter inside the tank was touching the tank and resonating. Dealer carefully persuaded it away enought to stop it making contact. Did not have to take anything apart.
Now in the happy zone, that is another story, all sorts of things start to buzz - the way they should!!!
Trying to locate the area the buzz is most likely coming from is the hardest.
Member #192
"Life is a curve!"
"Life is a curve!"
