helmet problems
helmet problems
Hi,sorry but this is not bike related question for many,but I have sort of a problem with my helmet.I have CABERG 104 Solo, which I just bought.After riding several times is occur to me that helmet is far more noisy than any other helmet. It is so bad that I was forced to desend from interstate,due to wind noise and turbolence.My ears actualy start to hurt after like 30 minutes of riding,despite using earsplugs.It is unfortunate that I can't buy another helmet,because of money shortage.(and wife)Please if any of you have sugestion,iam desperate for help.I cannot ride like this,and summer is comming.Maybe there is some web page,or sollution how to deflect the wind.So much for quiet,wind tunnel tested and expensive helmet.Also no return is possible this time.Thankyou so much in advance for your input. regards Mark
GERMANIA WERKE Nr;1150 R
Re: helmet problems
My suggestion would be earplugs. This WebBikeWorld site http://www.webbikeworld.com/Earplugs/earplugs.htm has some recommendations on hearing protection and some interesting links (e. g., studies on helmet noise & hearing loss). I use the Heartech plugs which I found on the site and have been very pleased.
Charlie
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
Re: helmet problems
Reef,
You don't mention if you ride behind a windscreen or not. If you do, it may be the reason for the excess wind noise. Helmets are designed for a clean air stream, not the turbulence often caused by windscreens.
You may also want to shop around for some better earplugs.
Re: helmet problems
Hi,I don't use windscreen,and I am using regular ear plugs
Re: helmet problems
My son just got this one from New Enough. This helmet has a good reviews and my son says that it has less noise than his old Nolan helmet. For 72 bucks it is worth a try.
http://www.newenough.com/closeouts/helm ... elmet.html
Good Luck.
Good Luck.
Lifetime Member #586
2002 R1150R
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
2002 R1150R
2004 R1150 ABS
2003 F650 CSA
Re: helmet problems
...never tried it myself, but this thingy might help...
http://www.cyclegear.com/spgm.cfm?L1=&L ... m=MRX_MSW3
"This plan was fool proof, yes! Idiot proof, no!"
Re: helmet problems
...Looks like it might; seems to me that the wind noise comes in through the bottom of the helmet. I just ordered one. I'll report on effectiveness when it arrives.
Re: helmet problems
Reef.....doesnt your lid have the rubber thingy under the chinto keep the wind out? I also have a Caberg Solo, and it is not loud at all. Maybe your helemt is too big, allowing the wind to pass between your melon and the helmet padding? Mine is tight, but still very comfy. Even with the visor 1/4 open the wind noise doesnt bother me
09 Someting??
Lifer 607
09 Someting??
Lifer 607
Re: helmet problems
hi,I just ordered windjammer 2 from UK,so this might help.I don't think that helmet is too big,it can't be any smaller then (L).I also trying some new ear plugs so hopefully that will solve the problem.Thank you so much for generous imput Mark
