Replacement battery advice
Curvedweller
Post by Curvedweller »
My original battery has expired (after 5 yrs. 8 mos., RIP) and reading all the posts below about what a PIA it is to replace or even check the fluid on R1150R batteries, and potential fuel line damage, etc., I'm looking for recommendations on the longest lasting, most maintenance-free replacement. I've searched a bit and see many folks like the Odyssey PC 680, but would a gel type last longer? My local bike shop is recommending a conventional Yuasa (ie: flooded electrolyte type) as plenty good enough, but I'm wondering since it's so hard to check fluid level, etc. Any advice appreciated. TIA
frbank6
Post by frbank6 »
I recently replaced mine for the first time. I was expecting the tank removal to be a big drama. but it really went a lot easier than I thought. That being said, I would still recommend you get the PC 680 battery. It just seems to be the most common solution when a new battery is needed, and while the tank thing isn't a big deal, it's not something I'm going to miss doing. It sounds like a lot of people have fuel line issues sooner or later, and frequent removal of the tank can't help the odds.
lombo
replacing battery
Post by lombo »
I agree I replaced mine two nights ago new battery I chose was the PC 680 easy change providing you have someone hold tank as you remove and replace.
Curvedweller
Thank you both for the feedback. Lombo do you mean you were able to replace the battery while keeping the fuel lines connected?
I'm a big fan of doing things the smarter easier way without cutting any corners. I have not tried removing the battery with the fuel lines attached since I have a WestCo maintenance free battery.
If you do it be very aware of this:
-- the fuel lines are short and very rigid
-- the QD's are plastic and not very strong
-- the damage you may do to the QD's may not show immediately
Think about it and watch what you are doing, slowly & very carefully.
