Fuel leaks
DK
Fuel leaks
Post by DK »
'04 R1150R Black
sjbmw
Moderator
Donating Member #: 263
Post by sjbmw »
Yes.
My recall was done back in 03, with my 600 mile service.
JCsman
Post by JCsman »
My dealer inspected mine, say no problemo and buttoned her back up.
I've contemplated injector clamps and a replacement for the QD's ever since.
I see there are brass ones out there for $75 +_ :shock:
If I replace mine I'm more likely to put in two short pieces of copper tube and put a couple of hose clamps/sqeezers in my kit.
By hose clamp, I don't mean like the injector clamps or like a small radiator hose clamp. I can't come up with the right term. But it's like a tiny vice that squeezes the fuel line to stop flow. Then you can remove the injector clamp and the gas will stay where she belongs.
Update after a Google break - damn faulty memory. I meant fuel line pincher. It helps prevent damage to the line when you squeeze it shut. Here's a link to one type.
http://www.shop.com/op/sprod-0-p4467767 ... tool-nover
- Bill #438, Lifetime
Post by DJ Downunder »
Thanks DK...but that recall is a joke IMO....they just look at the bike for a second..check that you're not leaking fuel all over the place..and if not..give you the thumbs up and send you on your way.
I had to ask my dealer to change over the spring type hose clamps with the screw type when they did a service for me..and offered to pay the extra cost to have them fitted.
Only to find out now that those spring clamps are only half the problem...I wish I had got rid of those fuel line quick disconects..they are like a sitting time bomb..just waiting to fail at any monent..of coarse they will wait till the worst possible moment to do so.
Those quick disconnects are not just a BMW problem..Ducati's and MV's have problems with them also..they are just not worth it IMO.. they could never ever fail..but you never know for sure.
DJ
Rich Hamilton
Post by Rich Hamilton »
You know what would instantly solve this problem? I fuel shut-off valve like most other motorcycles have. What's up with that BMW? Is a shut-off valve too low-brow for a BMW?
It would make removing the tank as simple as: Turn off valve, disconnect fuel hose that leads to the two throttle bodies, remove bolts, remove tank.
No mess, no having to drain the tank first and no leaky "quick-disconnects" (over-engineering at its finest). :roll:
It made pulling the tank from my old Honda a snap - shut off the valve, pull carb fuel line and remove two bolts - tank is off. All without having to drain the tank first.
Simplicity is the mother of conventional wisdom.... :wink:
2004 BMW R1150R Series 80-Alpine White (#131 of 200)
E=MC² (Enjoyment = Motorcycle X Clear skies²)
challey
Donating Member #: 365
Post by challey »
You know what would instantly solve this problem? A fuel shut-off valve like most other motorcycles have.
You ask too much of German engineers.
I bit the bullet and installed the Omega QDs. Much more robust than the cheezy plastic OEMs. Worth the $75 and 1/2 hour of work.
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
DK
Post by DK »
DJ,
I agree with you... I called BMW North America a few months ago and they said they were not aware of any problems with the QDs :shock:
When mine failed last year, it wasn't the O-ring but the disconnect that actually broke. I don't mind paying for the disconnect or the O-ring, I would like for BMW to fix the stain that results from a QD failure. But I'm not counting on that one :roll:
'04 R1150R Black
