Removing the idiot warnings?
motorrader
Post by motorrader »
Does anyone have a suggestion for removing the small stickers with fuel rating warnings, etc. on top of the tank, safely? :?: :?:
Motorrader
2004 R1150RA
2002 Z3
1990 M3
Dauntless
Post by Dauntless »
Heat them with a blow dryer and be patient or you will put tiny scratches in the paint.
I removed all of the stickers on my bike the day after I bought it. Couldn't stand them.
De-badging.
I just used my fingernail to peel up a corner, then carefully pulled the sticker off.
Sometimes a small amount of residue was left over, so I gently used a little Goof Off on a soft rag to finish the job.
A few coat's of Zymol on the paint, and I have a nice clean tank. :D
MikeCam
Centurion Moderator!
Donating Member #: 100
Halogen
Post by MikeCam »
500 watt halogen work light...5 minutes heat. Works better if you spray on some water or solvent as the heat builds. Peels right off.
Avoid more than 5 minutes unsupervised....those halogens get flammably hot.
motorrader
The stickers are gone. :D
Motorrader
2004 R1150RA
2002 Z3
1990 M3
