I would try and mount it where the stock one mounts...?I'll have to suss that out.
I could use that 'waste-of-space' area that I have under the tank because I don't have ABS.
It should be still ok for ABS bikes..a guy put one on his R1100S without any problems but he said this about the relay...
Old school relay direct to battery. It has been posted since that the stock horn is run by a relay which would save a little trouble but I have not checked the wiring diagram.
thanks for that DJ ...something to think about just before i
bring the RR out of storage.
I never liked stock horns on any bike.
IF the driver in the cage isn't doing a HOP out there seat ,
then you don't have there attention
That horn looks great. I also like that Nippy Norman's site. Take a look at the LED turn signals. They have a set that includes one row of red LED's with the yellow ones, the red row coming on as brake lights. Sounds great to me. LED's draw so little power I'm not sure if they would be a problem with ABS.
They also have a pretty cool accesory fuse box on the site.
