Clock Alignment
todehnal
Clock Alignment
Post by todehnal »
I have a standard 04 naked R1150R. The clock is NOT mounted with the 12, and 6 on a vertical plane like it should be. It is canted counter clockwise approximately 2 minutes. Now, the 00:02, and 00:32 are on the vertical plane. I see a small hex socket for an Alan wrench in the middle, on the back of the clock. I didn't want to go experimenting without some verification. It's a small thing, but I sure would like to straighten it up. Anybody been there and done that??? Tom
2004 R1150R
Buckster
Donating Member #: 543
Re: Clock Alignment
Post by Buckster »
Tightening that screw will not work. Personally I have not seen a fix for this. I haven't given it a whole lot of thought though. I remember taking the whole thing apart a few years ago and figured I would just deal with it.
Someone else may have a fix for it. I would be interested to hear it.
Buckster '03R
#543
shake1150
Re: Clock Alignment
Post by shake1150 »
Hi,
I had the same issue. Bugged the hell out of me!
I loosened the hex screw and lined up the clock, then I tightened the hex socket while holding the clock in its proper place.
Very easy... And now the clock is straight!
todehnal
Re: Clock Alignment
Post by todehnal »
shake1150 wrote:Hi,
Thanks Shake, I was considering going there, but it is nice to know that you had success with it. I will give it a try and post my experience for the next guy
Tom
2004 R1150R
todehnal
Re: Clock Alignment
Post by todehnal »
It Worked!! Five minutes and the clock is as straight as an arrow!!\
Thanks.............Tom
2004 R1150R
Zaasu
Re: Clock Alignment
Post by Zaasu »
A very timely fix.
2002, R1150R. Yellow with gray graphics. She is named Butter Cup!
Western North Carolins, NC, USA
Boxer
Donating Member #: 2
Re: Clock Alignment
Post by Boxer »
Man! You straightened THAT clock out!
