I've had the same problem with people running up on me. I just saw a product in the Whitehorse Gear catalog that sounds like it would take care of that problem - the Stobewise Deceleration Warning Device (http://www.whitehorsegear.com/strobewis ... ing-device). To quote their description, "Strobewise™ uses a small but sophisticated microprocessor to monitor your rate of acceleration 1,000 times per second. If you are slowing down at all, Strobewise™ illuminates its rear-facing high-powered amber LED lamp with flash patterns that are appropriate for your rate of deceleration. For example if you are lazily rolling off the throttle using light engine braking, Strobewise™ will provide a few gentle flashes. If you are braking moderately, the lamp warns other road users to your rear more firmly. Should you be in a full-on quick stop, Strobewise™ will respond with a machine gun stacatto of blazing high-intensity LED flashes."deilenberger wrote:I lost one side bag due to a rider running in the back of me, and a few people who follow me have commented that I never seem to use the brakes. So.. I've also gotten in the habit of flashing the brake light when I'm about to slow down setting up for a turn, or coming to a stop. I can almost come to a complete stop brakeless.. just need to use the brake to knock the last 5mph off..
I think that might be my next farkle. If I didn't need tires in the next month I'd buy one now. Just in case you're wondering, I'm not affiliated with WHG or whoever makes the Strobewise, although I kind of wish I was.
That's what I'm worried about - not my riding buddies but the general public.jameson71 wrote:That doesn't work for those of us who ride on public roads where random strangers are allowed?SF_Hooligan wrote:Or spend that money on something else and just ride with people who know how to ride. If someone rides close enough to my ass that they're all up in my business every time I slow down because they're focusing on my brake light, I wouldn't ride with them for long. On the other hand, no one can keep up with me anyway.
And about the canbus...can't one just use a fuseblock and hook it directly to the battery?
The description for the Strobewise says its compatible with CANBUS systems and specifically with BMWs but it does require connection to the speed signal generator wire.
Has anyone tried one of these things?
