Recently installed a BoosterPlug on my 2011 R1200R. Some comments for forum members interested in installing one.
1. It takes more than 10 minutes to install. But a beer and half an hour will see you through ok!
2. Remove the left hand lateral trim panel (Denoted item 2 on the assy drawing) and cover completely.
3. The Air temperature sensor connector is located at the top left of the air box.
To get to it, remove the M8 ISA torx screw (Denoted item 9 on the assy drawing) which holds the tank to the frame & pivot the fuel tank up around its bump stops (Denoted item 4 on the assy drawing)
TIP: make sure the fuel tank is not full!
4. Connect the BoosterPlug and route sensor cabling to suit.
Is the performance improvements as stated? Yes
Is it worth the $ outlay for that subtle enhancement? Yes
Compared to other farkles, is this a must have? Yes
The throttle response is much smoother, therefore I am satisfied that the outlay was worth it. Recommended
