Grips
Grips
The stockers seemed small, so I tried some Grip Puppies. They were bigger, but I've found they're slipprier, too: I have to reset my throttle hand every minute or so. The result (tighter grip and less security) is not as good as stock. It's actually easier to use the smaller stock grip because of its greater...well...grip.
Any options to replace the grips with larger rubber (or rubber-like) ones?
David Brick
Santa Cruz CA
Santa Cruz CA
- websterize
Re: Grips
I've been meaning to try these: http://beemerboneyard.com/foamgripcov.htmldbrick wrote:Any options to replace the grips with larger rubber (or rubber-like) ones?
Re: Grips
I haven't had the Beemerboneyard ones in hand, but I'll bet dollars to donuts they're Grip Puppies: same shape, size, and small price.websterize wrote:I've been meaning to try these: http://beemerboneyard.com/foamgripcov.htmldbrick wrote:Any options to replace the grips with larger rubber (or rubber-like) ones?
David Brick
Santa Cruz CA
Santa Cruz CA
Re: Grips
I've used the Beemerboneyard ones for the past 40,000 miles. I've never had them slip.
rockbottom
Re: Grips
My Puppies don't slip either. They did once when I screwed up and squirted straight detergent into them to install them rather than detergent and water.
Re: Grips
I'm not talking about the Puppies rotating around the grip; they don't do that. I'm finding that it takes a tighter grip than I'm used to or want to employ to keep the throttle open. That is, the glove/Grip Puppy interface has less friction than the glove/original grip does.
David Brick
Santa Cruz CA
Santa Cruz CA
Re: Grips
The Grip Puppies do significantly increase the grip's diameter. All else being equal, that will make them harder to hang on to ... or at least that's what I found the case to be.dbrick wrote:I'm not talking about the Puppies rotating around the grip; they don't do that. I'm finding that it takes a tighter grip than I'm used to or want to employ to keep the throttle open. That is, the glove/Grip Puppy interface has less friction than the glove/original grip does.
In years and on bikes past, I've been a huge fan of Pro Grips. They held up extremely well, were very "tacky" without being sticky (kind of like the pads you can put on your car's dash to keep your GPS from sliding).
However ... my R12R has heated grips, so removing the stock grips seemed like a non-starter.
Good roads,
- Lewellen
Re: Grips
I've also got a Throttle Rocker installed as well as the Grip Puppies thingie. Got one on my GS as well. I like those things alot.
Mike
1998 R 1100 GS
2008 R 1200 R
2006 Yamamhog Stratoloungerliner
1998 R 1100 GS
2008 R 1200 R
rockbottom
Re: Grips
Ahh, I see. I use Grip Puppies and a Cramp Buster.
Re: Grips
I agree a Throttle Rocker or Cramp Buster would be sometimes useful - there have been times I've wanted one. But I want things to be comfy from moment one on. I ordered these to try first: http://www.excelcyclewerkes.com/index_f ... ge1340.htm
David Brick
Santa Cruz CA
Santa Cruz CA
Re: Grips
And maybe it isn't the grips at all. In a 2008 thread, Bill Stevenson wrote:
Numb hands can come from a lot of things and we are all different. Make sure you are sitting in a neutral position on the saddle. By that I mean that without even thinking about it, you sit, stay in one place, and are not sliding forward or backward. If you are constantly having to push back in the seat, your hands will go numb. If you are constantly having to pull yourself forward, your sitz (I am trying to be polite here
) will go numb too. Neutral seating is one of the least understood areas of motorcycle ergonomics. People change handlebar height, use different grips, or gloves etc., but the real problem often is the saddle. BMW does not know how to make a good saddle in my opinion. For those of you who are also serious bicyclists you will know immediately what I am talking about because on a bicycle we adjust the saddle nose up or down to achieve a neutral seating position for our normal riding position on the bike (Note that this is closely linked to handlebar height and both should be sorted out together). For those of you who have not considered this aspect of bike setup, you could probably benefit if you heed this advice.
My numb hand problem went away with a Bill Mayer Saddle.
Well...I do slide forward, and a custom seat was already on my agenda. Perhaps it'll make further grip fiddling unnecessary.
David Brick
Santa Cruz CA
Santa Cruz CA
Re: Grips
Wow $15.00 for a bag of O rings! I think you could have gone to the auto parts store and saved yourself $10.00. Hopefully they work for youdbrick wrote:I agree a Throttle Rocker or Cramp Buster would be sometimes useful - there have been times I've wanted one. But I want things to be comfy from moment one on. I ordered these to try first: http://www.excelcyclewerkes.com/index_f ... ge1340.htm
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
Re: Grips
I'm kinda liking those O rings. In the rain, Grip Puppies will absorb water, where these will not. Also, they should offer a little ventilation, much like the stock grips. Think I might order a set...thanks for the heads up on these, and the site.
Mike
1998 R 1100 GS
2008 R 1200 R
1998 R 1100 GS
2008 R 1200 R
Re: Grips
I hope so too. The idea of buying a bunch of different sizes, figuring the correct size, and then going back to buy them in bulk ("I'd like 48 of part no. 3456-8765, please") just seemed like more than I want to take on.BigEasy wrote:Wow $15.00 for a bag of O rings! I think you could have gone to the auto parts store and saved yourself $10.00. Hopefully they work for you
David Brick
Santa Cruz CA
Santa Cruz CA
Re: Grips
dbrick wrote:I hope so too. The idea of buying a bunch of different sizes, figuring the correct size, and then going back to buy them in bulk ("I'd like 48 of part no. 3456-8765, please") just seemed like more than I want to take on.BigEasy wrote:Wow $15.00 for a bag of O rings! I think you could have gone to the auto parts store and saved yourself $10.00. Hopefully they work for you
That, and I like spending money with people like this. Took a few minutes to read thru his site.........pretty cool how he is teaching his grandson's while making his rather unique items. And besides, it was his idea to get these on the market. $ 15.00 ain't gonna break me and it certainly won't make him rich.
Mike
1998 R 1100 GS
2008 R 1200 R
1998 R 1100 GS
2008 R 1200 R
Re: Grips
You know, that's a really neat idea.dbrick wrote:I agree a Throttle Rocker or Cramp Buster would be sometimes useful - there have been times I've wanted one. But I want things to be comfy from moment one on. I ordered these to try first: http://www.excelcyclewerkes.com/index_f ... ge1340.htm
I found the stock grips to be a little too small in diameter for me, but the Grip Puppy-d grips are a little too large.
With an O-ring, you set the ID and can (in principle) vary the thickness ... interesting!
Thanks!
- Lewellen
Re: Grips
Back in the saddle again after a family road trip, I installed Tom's O-rings on the stock R12R grips.
They are a definite improvement over stock, both because they're larger and provide better grip on the palm. I haven't done more than a little in-town riding, but I expect that the greater grip will result in my not having to constantly readjust my hand position. They're way better than Grip Puppies.
David Brick
Santa Cruz CA
Santa Cruz CA
Re: Grips
What an great idea. I've never been pleased with BMW grips. But, have always shyed away from foam type covers fearing interferance with the heated grips. I would think the O-ring system would increase the diameter, have good grip with bare hands or gloves and allow heat to pass threw. I'm sold. I contacted Excel Cycle Werkes earlier to order a set for my 2007 R1200R. Once installed, I'll pass on a review.
Russ
N.E. Florida
Russ
N.E. Florida
waynemathews
- Triple Lifer
Re: Grips
I tried the Grip Puppies, and found them a bit too big around for comfort. I looked back to the BMW grips on my R100S which are tapered with the inside (thumb side) the smaller diameter. I cut a grip puppy in half and installed one half on each grip, and have been very pleased.lewellen wrote:The Grip Puppies do significantly increase the grip's diameter. All else being equal, that will make them harder to hang on to ... or at least that's what I found the case to be.dbrick wrote:I'm not talking about the Puppies rotating around the grip; they don't do that. I'm finding that it takes a tighter grip than I'm used to or want to employ to keep the throttle open. That is, the glove/Grip Puppy interface has less friction than the glove/original grip does.
Good roads,
- Lewellen
09 R1200R
