Shifter adjustment
ipokebadgers
Donating Member #: 913
Shifter adjustment
Post by ipokebadgers »
Hi all,
I am picking up my new-to-me 2007 R1200R next week and riding it home. I will need to adjust the shifter a little to make room for my size 13 boots. I have searched and learned it seems easy to do. Can someone tell me what type and size wrench is needed? From what I gathered from what I have read and the pictures I have seen you just loosen the one bolt clamp and move the shifter on the splines. Is there anything else I need to do or not do?
Thanks,
Sean
2000 K1200LT(Gone)
1978 R100S (Gone but not forgotten)
waynemathews
Triple Lifer
Re: Shifter adjustment
Post by waynemathews »
ipokebadgers wrote:Hi all,
That the procedure. You'll need an E8 external torx. The tightening torque is 8 NM. There's an index mark on the gearshift shaft for reference.
09 R1200R
toomanybikes
Post by toomanybikes »
When you remove the external torx, replace it with an allen. That is the only external torx bolt on the bike, and you don't want to have to carry a special wrench just for that.
Ron
1971 Norton
2008 YZ450F
2008 YZ250F
2002 TTR125L
toomanybikes wrote:When you remove the external torx, replace it with an allen. That is the only external torx bolt on the bike, and you don't want to have to carry a special wrench just for that.
Ah - but then you have to carry an Allen.. and there is only one other Allen on the bike that I know of - all the rest are Torx..
BTW - I forget if it's an 8mm or 7mm box wrench fits just fine... that's what I used.
I'm not sure if I have any external Torx wrenches , i know for sure I don't carry any.
All of this time I have been so vunerable riding around without one, I shutter. :lol:
mistral
Post by mistral »
You can actually use a small socket. I can't remember what size fits, but I carry one.
Ron
dbrick
Donating Member #: 902
Post by dbrick »
I changed the E8 for a hex-head bolt from my bolt drawer. Works fine. Tossed a 10mm open-end wrench in the toolbag.
David Brick
Santa Cruz CA
That sounds like a good idea. I DO have plenty of 10mm wrenches around.
jess
Post by jess »
deilenberger wrote:Ah - but then you have to carry an Allen.. and there is only one other Allen on the bike that I know of - all the rest are Torx..
...unless you have any third-party items bolted to your bike, in which case you're probably already carrying allen wrenches.
deilenberger wrote:BTW - I forget if it's an 8mm or 7mm box wrench fits just fine... that's what I used.
Good to know! Though I ordered a set of external torx sockets yesterday. :(
