Engine
Type
Liquid-cooled, DOHC, in-line 3-cylinder
Capacity
2294cc
Bore/Stroke
101.6 x 94.3mm
Compression Ratio
8.7:1
Fuel System
Multipoint sequential electronic fuel injection with twin butterflies and progressive linkage on primary butterflies
Transmission
Final Drive
Shaft
Clutch
Wet, multi-plate
Gearbox
5-speed constant mesh
Cycle Parts
Frame
Tubular steel, twin spine
Swingarm
Twin-sided, steel (houses drive shaft)
Front Wheel
Cast aluminum alloy 5-spoke, 17 x 3.5in
Rear Wheel
Cast aluminum alloy 5-spoke, 16 x 7.5in
Front Tyre
150/80 R17
Rear Tyre
240/50 R 16
Front Suspension
Kayaba 43mm upside down forks, 120mm travel
Rear Suspension
Kayaba black spring twin shocks with 5 position adjustable preload, 105mm wheel travel
Front Brakes
Twin 320mm floating discs, Nissin 4-piston fixed calipers, Nissin ABS system
Rear Brakes
Single 316mm fixed disc, Brembo 2-piston floating caliper, Nissin ABS system
Dimensions
Length
98.3 in
Width (Handlebars)
38.2 in
Height
45.8 in
Seat Height
29.5 in
Wheelbase
66.7 in
Rake/Trail
32 degree / 148 mm
Wet weight
807 lbs
Fuel Tank Capacity
6.3 gals
Performance (measured at crankshaft to 95/1/EC)
Maximum Power EC
146bhp @ 5,750 rpm
Maximum Torque EC
163 ft.lbs @ 2,750 rpm
Colours
Phantom Black, Matte Black
Price
