Rockster Front Fender
Xdot
Post by Xdot »
I actually own an '02 R1150R. Don't really care for the front fender arrangement. Would prefer a Rockster fender. The carbon fiber replacements are nice but I can't really justify the cost. Anyone have a lead on where I might find a Rockster front fender either new or used?
Thanks, john
2017 Husqvarna 701
2007 Husqvarna TE250
2004 BMW Rockster
jas
Re: Rockster Front Fender
Post by jas »
Unless you fabricate a mounting bracket to use with the fender, the S/Rockster models front fender will not work on a Roadster. Type "debeak, "beakless" or "Beak" in the search function and it should return a bunch of information on the subject. A friend tried to mount the Rockster fendeer on an 1150r with no luck and ended up using the K bike option instead.
2004 Roc.
Xdot
Post by Xdot »
jas wrote:Unless you fabricate a mounting bracket to use with the fender, the S/Rockster models front fender will not work on a Roadster. Type "debeak, "beakless" or "Beak" in the search function and it should return a bunch of information on the subject. A friend tried to mount the Rockster fendeer on an 1150r with no luck and ended up using the K bike option instead.
Cool. Thanks.
2017 Husqvarna 701
2004 BMW Rockster
sweatmark
Septuple Lifer
Donating Member #: 208
Post by sweatmark »
Ditto what jas says about Rockster/R1100S fender - won't fit R1150R Roadster without mounting adapter, as Rockster/R1100S forks differ from other R1150/1100 bikes.
Here's the R1150R Roadster fender option that I'd choose - this is how "rivi", long-time member of the board, customized his Roadster:
One of the sharpest Roadsters I've ever seen. Those are R1150RS fender pieces ("front mudguard", fiche diagram 46_0242, R22).
Xdot
Post by Xdot »
This is an interesting possibility from Hesa. And only $170.
2017 Husqvarna 701
2004 BMW Rockster
