I'm hoping to come up with a different diagnosis than the obvious one because I know how everyone feels about the problem I 'could' be having.
I've been having a recurring problem downshifting from 2nd to 1st. I REALLY don't want the problem to be what I think [not saying it].
I have an 04 RR with 26,6xx miles on it. I bought it used (2 previous owners) with about 24K miles on it. It seemed to have been maintained properly and looks great. Brian helped me change out the QDs, gave it a general inspection and thought it looked good.
Anyway, back to the problem. I've had problems downshifting. This has been happening with regularity over the last 2 weeks on my 9 mile commute to and from work. I know I'm not in first, I keep engaging the clutch and trying to get it into first and it just won't go. I stop at the light and when I take off it seems that I'm still in second because I have less power and have to goose it to get going. I've also been getting whiffs of that lovely burning clutch smell (even when I haven't had an 'episode').
I've tried to chalk it up to user error, but I've been acutely aware of it lately, and try to shift firmly and quickly, so I can't attribute the problem to my shifting anymore. I recently bought some new boots and thought that less flexibility in the ankle could be causing problems, but nope.
I've also had issues from time to time when I up shift. Usually after you shift, the transmission engages and there's tension in the shifter again (like having the ability to preload the shifter). I've had a few times when I couldn't get the tension back. The shifter was limp and I couldn't get it to catch so I could do my next shift. Finally after fumbling with it a few seconds I could get it to catch. Might be user error, as I'm still somewhat new to BMW (only 2K miles) but thought I should mention it here.
I've checked the clutch fluid and the level is fine. It doesn't seem dark either. I don't see any leaks under the bike either.
I'm not very mechanical and so I'm hoping that the problem isn't the spline issue (okay, there I said it).
Any diagnoses would be appreciated.
TIA.
