Clutch relining source
macx
Post by macx »
Hi
I don't really belong here, I've got an 1150, but thought you folks may also be able
to benefit from this info.
Have mine apart to check & lube trans input & clutch splines and found my clutch
disc very close to gone at only 32k.
Researched extensively, looked at other options, here's the best deal I could find
for my 165mm dia clutch disc.
Contacted several outfits I uncovered during a search, with no response.
However, followed up on a link I found in a post listed on the search result.
Lonnie
Clutchmasters
267 East Valley Blvd
City of Rialto, CA 92376
909-877-6800
www.clutchmasters.com
They don't say anything about motorcycle clutch relining on their website
Real nice guy to deal with.
He said they reline quite a few RT-P bikes. (mentioned having relined
200+ for the Las Vegas police) When I asked what they use,
assuming it was a more durable clutch, he said they use either ceramic or
metallic linings, but cautioned that those are much harder on the pressure
plate surfaces. He said some lasted well, some didn't. I would imagine it
would depend a lot on the individual rider. I didn't think it wise to trade a
little extra clutch life for having to replace the much more expensive
pressure plate replacement sooner at the least.
He did say they have a more durable organic lining he could put on.
He said he could turn mine around in 1 day from when he gets it.
Price was reasonable at $95.00.
It's going out on express mail in the morning.
I'll put pics on Photobucket when I get it and post a link.
omg1010
Re: Clutch relining source
Post by omg1010 »
Good morning,
32k is a bit low but depending on the riding style of the previous owner(s) this is certainly possible. I would certainly not recommend getting the clutch plate refurbished as usually near the EOL of your clutch other parts (such as the pressure plate) will also fail. Hence it is always advisable to change the whole clutch. Simply because comparing the work involved to change the clutch and what you save by refurbishing is not worth it.
Best regards
Oliver
raceratb
Post by raceratb »
I had my clutch done by them, and am very happy with the results. from my understanding you usually replace the pressure plates with the disk. clutchmasters resurfaced both pressure plates and made the new disc with a sprung center so its a little smoother. i posted pics of the setup if you are interested, just search my posts
