Headlight bulb replacement
Goman
Donating Member #: 666
Post by Goman »
No manual. How do I replace the LO Beam bulb? Does the nacell have to come off or can It be done from the rear? TIA :oops:
BMWMOA#52378
BMW Riders of Tampa Bay
'95 R1100 RSL
'04 R1150 Rockster 80 Ed. #1890
Member #666
Goman
Re: Headlight bulb replacement
Post by Goman »
Never mind.I figured it out. FYI..... unplug the connector in back. Twist off the plastic housing if you can and the bulb is accesable. I took off the nacelle and eyebrow, removed two large screws, holding the headlights in place and could then easly get the plastic housing off. It's tough to do from the rear! Unless your Greek!
BMWMOA#52378
'95 R1100 RSL
Member #666
louis2m
Post by louis2m »
Be smart put a XENON unit in your ROCKSTER! =D>
Goman
Post by Goman »
I have one in the high beam side. A super white Halogen. It costs 21 dollars US, so I replaced the low beam side with a conventional because it is on all the time. The Halogen lasts only 1/3 as long also. With the high beam at night, I see just great................ :biggrin:
BMWMOA#52378
'95 R1100 RSL
Member #666
