After fitting my Remus Y pipe and Genesis oval alloy can, the quiet one, the tick over increased to about 1400 revs.
Then a plug coil failed on me so I replaced both of them.
So now when I know everything is OK and I finally got round to balancing the carbs and setting the tick over. She now runs sweetly and the tick over is about 1100 rpm.
My only other issue is do I need to check the mixtures and if so is there a cheap way of doing it apart from plug chops?
I am planning a touring trip soon and really don’t want to have to worry and weak mixtures and holing a piston, again.
She is an 04 1150R twin spark with a Remus Y pipe and a quiet Genesis oval alloy can. K&N Air filter installed. The O2 sensor installed. 25K miles
Any advice is gratefully received.
Many thanks
-Basmaf
