Searching for an aftermarket Silencer for R1200R
Rocket
Post by Rocket »
Just started to research this topic since a replacement silencer is on my list of intended modifications for my newly acquired RR
The bike has the stock stainless steel silencer which , although makes a pleasant sound, is on the large side (and ,I presume, is heavy). So the hunt is on for an aftermarket replacement.
Would very much appreciate opinions, information, pictures , etc on the subject.
Ron
Rocket
2007 R1200R (Black)
2006 KTM 400 EXC (Orange,.. obviously)
TIME TO LIVE A LITTLE
08_r1200r
Donating Member #: 796
Re: Searching for an aftermarket Silencer for R1200R
Post by 08_r1200r »
I'm in the exact same boat. I do not want "LOUD", I just want something smaller, sleaker looking, and ... this seems to be the hardest part ... NOT have a giant name on the side of the manufacturer. Just a good looking exhaust that hopefully provides some extra bhp too.
mogu83
Post by mogu83 »
Guys - If you do a search on mufflers/exhaust you will find a wealth of information on this subject. When the R first came out their was a scramble for aftermarket exhausts (systems and slip-ons) . I think you can find (in past posts) members on this list that have installed just about every type of exhaust that is out there. If you have an interest in a particular manufacturer just do a search on it.
Bottom line is their isn't much to be gained over the stock exhaust, a few HP on top and a little more sound (not noise).
I'm using a ZTechnic slip-on, a little lighter, and a tiny bit louder that stock with the DB killer in.
crazyhorse
Post by crazyhorse »
my Ztechnic is nice, however it is a tad bit louder and pops sometimes on abrupt throttle roll-off. i don't like louder either, that was a goal.
it has a db killer core, which i tried out for a day, and it made my ears hurt. of course i got lots of attention, but that's not what i want.
it's nice and sleek and understated, you should check it out. it's a bit more hp but to get rid of the mid 'flat-ish' spot (i feel crazy stating my r12r has a flat spot) you must take the db killer out. there is hardly a difference.
wes
The Stuck Canuck
In Garage:
08 R1200R
08 WR250R
alaskaflyer
Post by alaskaflyer »
I have the Staintune slip on installed on my R, if you'd like to see what it looks like my bike is listed in the Buy/Sell forum. You can remove the baffle or keep it in. I run mine with baffle out (I think it's more of a silencer plug) and its a little louder than stock.
Gary
2008 BMW R1200R
***RIP Crew of Coast Guard 6505***
dderrig
Post by dderrig »
This is what you want! Good looking and choice of stock sound with Baffle or Sporty without Baffle all for $600.
Dave
2007 Black Pinstriped R1200R
Rocket
Post by Rocket »
Lovely looking bikes guys =D> =D>
Thanks for the response
Rocket
2007 R1200R (Black)
hjsbmw
Donating Member #: 711
Post by hjsbmw »
dderrig wrote:This is what you want! Good looking and choice of stock sound with Baffle or Sporty without Baffle all for $600.Dave
How's the case clearance? Did it alter your mpg?
Harald
2007 BMW R1200R
lewellen
Donating Member #: 635
Post by lewellen »
And .. what brand was it? Is it the full system?
From what I just looked up the Staintune can actually wind up being a little quieter than stock...which is appealing to me. :-)
Good roads,
- Lewellen
dderrig
Post by dderrig »
Good roads,
- Lewellen
I've "Heard" case clearance was good in another thread but can't verify as I don't have cases yet but will soon. Not the full system (Made by LeoVince), just a slip on and have not noticed much change in mileage although to me I think it rides better in the lower gears, especially first as it seems less sensitive (Jerky/jumpy) to minute throttle variations with the baffle removed. Also with the baffle removed the feeback sonically helps me when downshifting/engine braking as to how much throttle to give for smoother engine braking.
Dave
ScottSuff
Post by ScottSuff »
I have the Leo and I'm very pleased with the look and sound. It is well made and has the clearance on the left system case no problem. You just have to adjust the pipes to get the correct angle on the case.
Scott TN Hills
2008 R1200R Black
2006 Triumph Tiger
1999 BMW 650 Funduro
hjsbmw
Post by hjsbmw »
Looked at my oem can. The connector has a flange on which the center stand rests with a rubber stopper. Does the Leo Vince have that also?
Harald
2007 BMW R1200R
dderrig
Post by dderrig »
Yes the LeoVince has the stopper for the center stand.
Dave
