It is possible or maybe I am being really paranoid but I suspect that I may have the dreaded clutch slave issue with my 04 1150R.
She has done just shy of 25K miles and just had her 24K service where the clutch fluid was replaced. I asked the mechanic to check the clutch over, and he said he could find nothing wrong and everything seemed ok but I am still not so sure.
The issue manifests it self as
From cold it can take 3 or 4 or sometimes even 5 pumps of the clutch leaver before she will engage first gear, sometimes I even have to paddle her back a few inches before she will engage as well.
When she is warm, and the engine has been off for a few minuets, when fuelling etc, it can take a couple of lever pumps to get her into first again.
When warm the clutch bite point starts at about a third of the way along the lever travel.
I don’t seem to have a problem when the engine is running and neutral is easy to find, as is first when setting off.
Sorry about not having much info but any advice would be very gratefully received.
Many thanks
Basmaf
